Posted May 15, 201016 yr Alright guys i finally got my FI Dual 1 ohm 12 Bl today and went to installing the sub.As I turned on my deck i received sound from the speakers but no sound came from the subwoofer.1. I checked the amp (Alpine MRP-1000) Amp light turns on.2. I checked the rCA'S even switched the RCA'S between both amps no sound from the subwoofer.3. I checked the deck and switched the subwoofer rca's from subwoofer input and rear space input. still no sound4. I checked to see if the amp was getting enough power and it was at 12.5 volts at rest5.i turned on the subwoofer option on and off on the deck and still no sound.6. I turned th e gain up on the subwoofer from minimum to max and still no sound7. I checked the fuses on the amp I dont know what else to do or check for. I know it cant be the sub cause its brand new.The only other information i can give is before i had this subwoofer i blew a alpine type x cause i didnt have the gain set correctly. Whenever i went to look there was only smoke coming from the box.Any Ideas whats wrong?
May 15, 201016 yr have you tried swapping out the alpine amp for another one? that would be the next step i would take
May 15, 201016 yr Author i guess ill go up to a shop and have them test another amp on it. just sucks for this to happen i was expecting to just plug and play.
May 15, 201016 yr Have you checked all your sub wiring? You could have a bad connection in the box or to the amp.
May 15, 201016 yr Author i got bored and decided to see if it was the amp so i wired the subwoofer up to my 4 channel amp and it played sound like it was nothing. so what do yall think could be wrong with the alpine amp. the light comes on but thats all it does. the last time i used this amp was march 2009 when i blew the type x.
May 15, 201016 yr i agree with duran u probably killed the amp which in turn killed the type x have u tried the amp on another speaker?
May 15, 201016 yr Sounds like you clipped the shit out of it. There's a shop in Buda called audio outlaws that I beleive does amp repair. He deals alpine so I'm sure he's familiar with your amp.512 295 7617 give em a call tomorrow!
May 15, 201016 yr Author naw i havent tried any other speakers. thanks for the number rodney ill give them a call tomorrow. hell i already started looking for 2 ohm amps putting out 1500 watts lol
May 15, 201016 yr Author after doing some research its hard as hell to find a good amp putting 1000+ watts thats 2 ohms stable for at least $350 Edited May 15, 201016 yr by wutang512
May 15, 201016 yr Author now that i think about it. this amp isnt even worth getting fixed since it doesnt even have a subsonic filter on it.
May 15, 201016 yr You could get a Crescendo 3KWP that puts out 1650 at 2 ohms, 3370 at 1 ohm for $549. Why did you decide to go with the dual 1 instead of dual 2 so you could run at 1 ohm?
May 15, 201016 yr Author You could get a Crescendo 3KWP that puts out 1650 at 2 ohms, 3370 at 1 ohm for $549. Why did you decide to go with the dual 1 instead of dual 2 so you could run at 1 ohm?That crecendo is nice but its out of my range as far as price. I didnt want to spend more than $350 on a new amp but still get at the most 1500 watts at 2 ohms. i bought the dual 1 because I already had the amp and it runs 1000 watts at 2 ohms.I didnt know the amp was busted until yesterday. I hadnt touched the amp since march of 2009. It had just been hooked up in my car chillin the whole time. Edited May 15, 201016 yr by wutang512
May 15, 201016 yr I think it might be tough to find an amp for under $350 that puts out 1500 at 2 ohm, a quality one anyways. Thats why I got the dual 2s, because it seems that you can find alot more amps that put out 1500 at 1 ohm for around $350. I got my T1500-1bd (which on the birth sheet says that it was tested at 1796 watts at 1 ohm) for $395 shipped, brand new.
May 16, 201016 yr Author found a decent amp. its a Soundstream DTR1.2200D. puts out 1400 at 2 ohms stable . a couple people at caraudio.com recommend it. seen it going for $ 338
May 16, 201016 yr found a decent amp. its a Soundstream DTR1.2200D. puts out 1400 at 2 ohms stable . a couple people at caraudio.com recommend it. seen it going for $ 338Used? It retails for $599, I've searched and can't find it any cheaper than around $449.
May 16, 201016 yr You could get a Crescendo 3KWP that puts out 1650 at 2 ohms, 3370 at 1 ohm for $549. Why did you decide to go with the dual 1 instead of dual 2 so you could run at 1 ohm?Because the alpine is only two ohm stable. I think they have a set subsonic filter but its set to like 15 Hz so its practically worthless
May 16, 201016 yr Author so then what do y'all usually with broken amps. should i just throw it away...
May 16, 201016 yr so then what do y'all usually with broken amps. should i just throw it away...I guess I would see how much it is to repair it. Even if you decide you don't want it anyway, at least the repair might be cheap enough that you could sell the amp for more than the repair.
