what is the speaker wire gauge for a Fi BTL?
12gauge would work fine, but you could also use 10 gauge if it matters that much to you. But it wont make a noticeable difference.
12awg should work fine but as stated, u can go with the 10awg for ur satisfaction.
No one has asked how much power and what ohm load. Hmmmm. . .
If he's asking a forum... its probably not over 2kW. Which means 12awg will be more than adequate..
8
iam going to have 2 Fi BTL's with 2000 watt rms 4000 watt peak amp at 1 ohm
Max watts means nothing. If you ever get close to the max wattage rating you will easily blow your amp and sub.
What amp(s) are you intending on using? What does your electrical consist of? The word "peak" isn't a good sign...
If you have to ask this question, use no more than 2,000 watts.
