Posted August 18, 200520 yr i'm trying to get a QTC of .707 out of my Rl-is in my new box.So far these are my calculations..267 = QTS 44.74L = 1.57cf = VasVb = 1.57/((.707/.267)^2-1)Vb = 1.57/(6.011)VB = .26So is this the net volume i should be shooting for for 1 rl-i?I want to port it i haven't grasped the complete understanding of QTC but realize .707 is ideal and depending on which way i go i will gain some low end lose wattage handling, or gain handling of power and get some peakiness. But i don't understand if a port and the tuning will affect the QTC or if i could go for a higher QTC and a lower tuning to gain the same type of output.THanks for your time~Mike
August 18, 200520 yr Soundsplinter's subs model weird ... aim for something in the 0.6-0.75ft^3 range for the Q to be ~ 0.707. Have a look at the curves here:http://www.soundsplinter.com/rli_series/rl...nformation.html
August 19, 200520 yr Author so you think 1.5 net in a ported enclosure would be about good?tuned around 30
August 19, 200520 yr Screw the 707! .. and in my opinion that 1.5 cu ft enclosure @ 30 is just going to be too peaky (UNLESS you're talkin' about both drivers @ .75 a piece.. which is certainly doable) RL-i10 's should aim for a 0.75 - 0.85 cu ft net (0.85 - 0.95 cu ft gross internal) volume vented enclosure tuned from 28-30 Hz with apx 20 sq in of port area Power with 250-350 watts per driver and you're good to go B)
