So I was wondering what is the best way to secure an enclosure in a car ? Preferably not permanent, but so it can't be stolen or so it won't slide around.
It's a 9cuft box, and its going in the back of my Jeep Cherokee.
bolt it down on the inside of the enclosure, big bolts :D
yeah, look for factory bolts to use if you want to return it to stock later on. for example, my xterra had some cargo hooks bolted to the floor. i took them out and went to napa to get longer replacement bolts. then it was just a matter of drilling the box and installing the longer bolts with some large washers.
L brackets would do it. Attach to the box then the trunk floor.
Yea I was recommended those by someone else. Might go with those. Straight bolts might be easier though.
in my trunk i just used velcro (hook side) on the bottom of the box. stuck to the carpet pretty well..
edit: just read your putting it in a Cherokee so skip the velcro.. nothing to stop box from flying around in that vehicle beside bolting that thing down
Yea it would for sure be a problem if it was sliding around lol.
Edited by hatrix
b4 i put my sub in the box i drilled about 8-10 holes in the bottom of my box then used some self tapping screws straight thru the floor.......i was gonna do brackets then decided on this cause any random thief w/ a screw driver can undo the brackets.....so with box bolted to floor and allen head bolts and t-nuts me sub is secure. the most they cold do is trash my sub but thats wut recones r for lol
