Yes there is. :)
You can wire it in series.
Thats exactly what i was thinkin but my know-it-all friend was trying to convince me that its not possible. We all have those friends i guess. Thanks mayneee.
Yes there is. :)
Just take a DMM to check, and show him it is possible. Teach him.
Anytime. :)
Yes there is. :)
Anytime. :)
Ha, will do. U think ill be happy (output-wise) hookin that amp up to a 10" Bl?
Yes there is. :)
Anytime. :)
I don't know what your looking for? Or how loud your other systems have been. So that's all about what you like.
Just show your friend this picture:
Hi guys, Im going to wire my Fi Q12 Dual 1 ohm into single 2 ohms load. What type of jumper should I use and also the gauge size number?
Thanks
10 -14 guage for subwoofers and if you want to do 8 gauge then it will be overkill and require some modifications to the wire.
Yeah that should be fine, what amp are you using for this kit? Anything under 1200 watts will suffice.
What gauge do you suggest for me?
12
Most likely my buddys RF R500.1 (500 @ 2ohms) but my decisions still pending on the amp. Got a suggestion? (budget ride)
