August 30, 200521 yr but then again, not everyone can build stuff...or else there wouldn't be a need for mass produced, prefabbed anything...And even then.....sometimes those of us who can build stuff simply don't have the motivation to build stuff :lf: wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee Guess I walked right into that one..............yeah, and i got to use some of the new smilies.... hehewheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
August 31, 200521 yr The "asshat" and "boo-pucking-hoo" are ones that are going to see some action over on CA.com <{POST_SNAPBACK}>bandwagon one too
August 31, 200521 yr http://cgi.ebay.com/Klipsch-Chorus-II-Spea...1QQcmdZViewItem98 dB/W. Basically a beefed-up version of the Forte's.Kickass.
August 31, 200521 yr http://www.mitekfactoryoutlet.com/products...TP212&colorid=0I'll take those instead...and put on a concert for under 500 bucks :
August 31, 200520 yr DunoI'd say pro sound stuff...woofers should go down to 50-55Hz...probalby 50-20kHz?
September 1, 200520 yr DunoI'd say pro sound stuff...woofers should go down to 50-55Hz...probalby 50-20kHz?<{POST_SNAPBACK}>that sounds about right my mackie mixer board sub output says 75 -hertz down. The other boxes say 36-130 for the subs and 36-30,000 for the full ranges. So It may go all the way down.
