Posted June 14, 201015 yr I was wondering if anyone would be able to make a sketchup for this box. and please correct me if my tuning is off. box is 4.33384 after sub displacement.W. 30H. 20.5D. 16wood thickness .75and the port being 32.5in long tuned to 32 hz with a kerfed radius of 3.
June 14, 201015 yr Author Sketchup is free! Give it a try ... i have tried 100 times and just can get the hang of it.
June 14, 201015 yr Still no port width. Assuming 2.5" for port width with a 3" flare radius, it looks correct. I have the enclosure at 3.16ft^3 @ 32.06hz with 15.05in^2/ft^3 of port area. If this is for your 15" BTL I'd consider more space as your going to want a double baffle and some bracing in there.
June 14, 201015 yr Author Still no port width. Assuming 2.5" for port width with a 3" flare radius, it looks correct. I have the enclosure at 3.16ft^3 @ 32.06hz with 15.05in^2/ft^3 of port area. If this is for your 15" BTL I'd consider more space as your going to want a double baffle and some bracing in there.i believe its 4 inches wide. i apologize.
June 15, 201015 yr Author i have been terrible in this post. i have just been brain farting all day i guess. i realized that i didnt take in counter that the port is going to take away area of the box.. fml give me a bit to re do this all. i apologize for waisting time.
