November 28, 201014 yr Author JOSH LOVIN CHOC SEKS !tripple baffleSEKS !MORE SEKSthis pic right here is the life saver... flush mounted with as additional ring on the inside. groove and flush mount lock sub into place !!!! no guess work as far as lining them up. also screw holes are place so that there arent anymore tight places to try n fit a drill in.also the additional ring on the inside serves as the seal against the surround for air tight seal of sealed section. FN GANGSTER IS ALL I CAN SAY ABOUT THIS....THIS IS THE BRIGHTEST IDEA IN CAR AUDIO SINCE IVE BEEN ON THIS FORUM
November 28, 201014 yr Author JUST IN CASE I HAVENT SAID IT YET... KCB FTMFW ! THIS WOULD NOT BE POSSIBLE IF NOT FOR HIM AND TWITT !
