Posted September 5, 200521 yr http://www.caraudio.com/vb/showthread.php?t=115401I started a thread on CA.com, im trying to come up with a good box, and im not really too happy with the frequency response my 2000SPL's offer using WinISD. This being a more serious, on topic forum, does anyone have any suggestions or answers to the questions asked on that thread?feel free to post either here or on CA.comThanks!Sergei
September 5, 200521 yr what exactly is ur current setup?playing around, i've got the best looking graphs to be about 4ft^3, tuned to 35hz, with two 4" round ports...ur lowend roll off starts at about 40hz...it's at -6db at 30hz, not counting car transfer funtion.anyway...i used 1kw as total input power..and the t/s specs from pioneers website...i'm sure we can do better with a bit more info....wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
September 16, 200521 yr need to know what sub modle you are using and T/S info, also will need to know the external dimentions of where you intend to put the box so we get a good fit and also dont forget to measure the trunk opening so it will go in after its built ! a lot of people forget this and cant get the box in the trunk after its built i am using Bas Box Pro 6 let me know if i can help this is a pic of my last build 8.03cf @ 40Hz after displacement of subs & ports
September 16, 200521 yr Don't pay much attention to the computer modeling graphs on widely available cheap or free programs. They are not too accurate. Even my $200 program is way off. You just can't simple rely on a computer programs "estimated" response. The higher end programs (read espensive) such as LEAP are very good, but also very pricy. I'd do a search and see what other are using and go from there, or start with the manufacturer's suggestions and tweak to your liking. I have had great experiences using Pioneers recommendations as a base and tweaking them where needed. The Manufacturers DO know their products well and their capabilities.
September 17, 200521 yr Don't pay much attention to the computer modeling graphs on widely available cheap or free programs. They are not too accurate. Even my $200 program is way off. You just can't simple rely on a computer programs "estimated" response. The higher end programs (read espensive) such as LEAP are very good, but also very pricy. I'd do a search and see what other are using and go from there, or start with the manufacturer's suggestions and tweak to your liking. I have had great experiences using Pioneers recommendations as a base and tweaking them where needed. The Manufacturers DO know their products well and their capabilities.<{POST_SNAPBACK}>Tirefryr,While I have to agree with you about enclosure modeling programs as being wholly inaccurate as to the cheap or online programs.In my experieence using Bass Box Pro 6 given all the enclosure's that I have designed and built and delivered, BBP 6 has yet to provide any unsatisfactory comments from any of those customers.As we all know, enclosure design programs are intended to be used as a tool to at least provide within reasonable expectations of bass response and performance given all the other known factors involved that are going to effect the subwoofer/enclosure after they are installed in the vehicle.
September 17, 200521 yr Author I've been doing a lot of calculations and I came up with a somewhat finalized box using WinISD. As for being perfectly accurate, im not too worried about that, im not going for perfection, but my main goal here is flat response up until the lower frequencies, where I'd like to have a large peak. The thread that I linked you guys too earlier I entered using the wrong T/S Parameters, which is why I have a huge dip in the mid-high bass frequencies.2 12" 2000SPL's4.00 cu.ft @34hz2 slot ports, 2.5" wide, 11" tall, 28" long+plenty of bracingI have a station wagon, so space and getting the box in is not a major concern, but I would like to keep the demensions around 36" width (necessary), 24" depth, and 14" hightHeres what the graph I came up with looks like:And the box will look something like this, subs facing up, ports facing back.Any opinions? comments? suggestions?
September 17, 200521 yr Don't pay much attention to the computer modeling graphs on widely available cheap or free programs. They are not too accurate. Even my $200 program is way off. You just can't simple rely on a computer programs "estimated" response. The higher end programs (read espensive) such as LEAP are very good, but also very pricy. I'd do a search and see what other are using and go from there, or start with the manufacturer's suggestions and tweak to your liking. I have had great experiences using Pioneers recommendations as a base and tweaking them where needed. The Manufacturers DO know their products well and their capabilities.Tirefryr,While I have to agree with you about enclosure modeling programs as being wholly inaccurate as to the cheap or online programs.In my experieence using Bass Box Pro 6 given all the enclosure's that I have designed and built and delivered, BBP 6 has yet to provide any unsatisfactory comments from any of those customers.As we all know, enclosure design programs are intended to be used as a tool to at least provide within reasonable expectations of bass response and performance given all the other known factors involved that are going to effect the subwoofer/enclosure after they are installed in the vehicle.Oh, I'm not saying it may produce an unsatisfactory result, I just don't want him to base his final enclosure based on nothing more than a plotted response graph from program. All I was trying to get through to him. OT: Nice to see you on the board!
September 18, 200521 yr i did a moc up of your box in BBP6 Box Properties Name: Type: Vented Box Shape: Prism, square Vb = 4 cu.ft Fb = 33.99 Hz Fill = none No. of Vents = 2 Vent shape = rectangle Vent ends = two flush Hv = 12.5 in Wv = 2.5 in Lv = 33.59 in
September 18, 200521 yr Author that looks like a sealed design to me BTW, I would like to have indented sides for this particular box. I suck at carpeting
September 18, 200521 yr the biggest downside to bb6p is that is doesn't figure slot ports accurately, as it pertains to the port's displacment. it also assumes you are going to build the port seperately and not use a wall as part of the port...you have to tweak the program a bit to get it close.otherwise, i'm extremely happy with bb6p and the results it's given me..however, i agree with ryan. while it will indeed give you an idea, one should not wholey rely upon it's graphs...unless you want to take the time to map out the frequency response of your vehicle so that the graph's can use the vehicle response as well. even then, i won't just assume that the bb6p graphs are 100% accurate.wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
September 18, 200521 yr the biggest downside to bb6p is that is doesn't figure slot ports accurately, as it pertains to the port's displacment. it also assumes you are going to build the port seperately and not use a wall as part of the port...you have to tweak the program a bit to get it close.otherwise, i'm extremely happy with bb6p and the results it's given me..however, i agree with ryan. while it will indeed give you an idea, one should not wholey rely upon it's graphs...unless you want to take the time to map out the frequency response of your vehicle so that the graph's can use the vehicle response as well. even then, i won't just assume that the bb6p graphs are 100% accurate.wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee <{POST_SNAPBACK}>Well, BBP 6 does calculate a slot port accurately given the way the program does model it within the Box Volume Displaced by the Port parameters.However, within those parameters, it has to be specified what the thickiness of the material being used noted by input " B ". The Box Volume Displaced by the Port parameters are not making any assumptions here, they are performing the function properlybased on the manner which the program was written to calculate either a round or slot port not to include any part of the enclosure itself.So, like a round port which is calculated to lenght based on the volume, diameter & tuning frequency, a slot port is calculated in thesame manner as if it were a separate part installed.Now, given that the majority of the time when we design ported enclosure's using slot ports, we're going to use the top, bottom, side & back forpart of the slot port walls. This leave's us with only having to determine the final port wall or walls that make up the rest of the slot port whichwe have to figure out their displacement which changes the parameters of the enclosure design.LB ( Lord Baccus ) asked me this question awhile back when he was trying to figure out a slot ported design in BBP 6 and his calculations were gettingtotally throw off because he could not understand which parameters within the program were causing the conflicting issue's.Rather than trying to explain it to him, he sent me his BBP 6 design and I sent him back my BBP 6 design of the same enclosure and referenced those parameters within the program to show the errors within the formula, once he saw both designs side by side, he gotit just like that.Your are totally correct, when designing slot ports within BBP 6, you have to totally zero out the parameters in the Box Volume Displaced by the Port parameters and use the Box Volume Displaced by Miscellaneous Objects to properly calculate the slot port parameters to account for both the Port Displacement and Port Wall Displacements.Granted, it's a royal PITA to calculate the slot port parameters accurately because you have to constantly re-adjust all the other parameters but I've discovered a few tweaks and using a calculator I created in EXCEL, I've reduced the amount of effort I need to apply for designing slot ported boxes in BBP 6 and in turn allow me to build enclosure's with a greater degree of satisfactory results in terms of bass response and performance once the customer recieves and installs the enclosure.We all agree that the other factors involved after the sub/enclosure are installed are going to skew the bass response/performance, none of us can deny that unknown element.PhilWoodlawn Cabinetry( NOT KENT )
September 18, 200521 yr the biggest downside to bb6p is that is doesn't figure slot ports accurately, as it pertains to the port's displacment. it also assumes you are going to build the port seperately and not use a wall as part of the port...you have to tweak the program a bit to get it close.otherwise, i'm extremely happy with bb6p and the results it's given me..however, i agree with ryan. while it will indeed give you an idea, one should not wholey rely upon it's graphs...unless you want to take the time to map out the frequency response of your vehicle so that the graph's can use the vehicle response as well. even then, i won't just assume that the bb6p graphs are 100% accurate.wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee Well, BBP 6 does calculate a slot port accurately given the way the program does model it within the Box Volume Displaced by the Port parameters.However, within those parameters, it has to be specified what the thickiness of the material being used noted by input " B ". The Box Volume Displaced by the Port parameters are not making any assumptions here, they are performing the function properlybased on the manner which the program was written to calculate either a round or slot port not to include any part of the enclosure itself.So, like a round port which is calculated to lenght based on the volume, diameter & tuning frequency, a slot port is calculated in thesame manner as if it were a separate part installed.Now, given that the majority of the time when we design ported enclosure's using slot ports, we're going to use the top, bottom, side & back forpart of the slot port walls. This leave's us with only having to determine the final port wall or walls that make up the rest of the slot port whichwe have to figure out their displacement which changes the parameters of the enclosure design.LB ( Lord Baccus ) asked me this question awhile back when he was trying to figure out a slot ported design in BBP 6 and his calculations were gettingtotally throw off because he could not understand which parameters within the program were causing the conflicting issue's.Rather than trying to explain it to him, he sent me his BBP 6 design and I sent him back my BBP 6 design of the same enclosure and referenced those parameters within the program to show the errors within the formula, once he saw both designs side by side, he gotit just like that.Your are totally correct, when designing slot ports within BBP 6, you have to totally zero out the parameters in the Box Volume Displaced by the Port parameters and use the Box Volume Displaced by Miscellaneous Objects to properly calculate the slot port parameters to account for both the Port Displacement and Port Wall Displacements.Granted, it's a royal PITA to calculate the slot port parameters accurately because you have to constantly re-adjust all the other parameters but I've discovered a few tweaks and using a calculator I created in EXCEL, I've reduced the amount of effort I need to apply for designing slot ported boxes in BBP 6 and in turn allow me to build enclosure's with a greater degree of satisfactory results in terms of bass response and performance once the customer recieves and installs the enclosure.We all agree that the other factors involved after the sub/enclosure are installed are going to skew the bass response/performance, none of us can deny that unknown element.PhilWoodlawn Cabinetry( NOT KENT )that's jsut what i was referring too, but i didn't put it so nicely, lol. you'll get used to me like that.and, btw, i'm Kent. nice to meet ya Phil!wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee:slayer:
September 19, 200521 yr BB6P is great, IMO ... Calculating slot displacement is easy ...Of course, I'd love to get my hands on LEAP 5.0 ... Unfortunately, I don't have $1200 laying around nor do I know where to get it for free ...
