Posted June 24, 201016 yr Well I thought I would start a build log even though my stuff doesn't even come close to what most of you are doing. lol Anyways, build will consist of the following stuff:1998 Ford Explorer Sport2- SSD 12's dual 1 ohmSoundstream RUB1600.1 ampAll Knuconceptz power/ ground wires 0 awg12 awg speaker wire250 amp altYellowtop under the hoodBig 3 w/ 0 awg40 CDL tiles from Don @ Sound Deadener Showdown just to tame the cargo area a bit. No front stage yet as I don't have the cash for them yet. I business partner has an alpine 5 channel amp with a center stage I can use when I do get the components. Not sure of the model though. Current system is an Orion 12 on 200 rms and the Explorer rattles pretty good already. Ill post a video of the baby flex from that 12 for fun in the next few days. hahaSo some pics of what I currently have installed and the gear going in.Orion 12, Obcon Box, Alpine amp.... Gets decently loud for what it is. Temp system while I saved up for all of the above.Alpine AmpNew 2010 SSD 12's StockAmp next to my buddies 2 channel RE amp I put in his car.Power wires, fuses, fuse holders, etc... Just came today. Crappy BB picHAHA! I totally forgot how big KC's ANL fuse holders were.... And a pic of my little man Jasper. Just because he is the coolest dude in the world! From his 1st Birthday last month. I have a wedding to shoot this Saturday so Sunday I start installing the power wires. Waiting on the CDL tiles and the HO alternator so Ill probably do 2 of 3 of the Big 3 and just run the Alt to batt wire for now.. Plenty More pics to come as I tear up, put down, install, etc... Hope to start the box this weekend. Around 4 cubes after displacement. Subs firing up and port to the rear. Trying to save as much cargo space as I can by doing it that way. I haul around A LOT of camera gear for shoots so I need the space. Still might go sealed but I haven't decided. I had planned on getting current system metered before I pull it but no shops around here have TL. 2 have old condenser mics and the 3rd had no clue what kind they had but they said it was super accurate. + or - 10 db... Yeah not .1 db... 10 db's! I told him I'd be better off saving my $40 and just guessing the db's. Probably more accurate too! Won't be calling them again... haha
June 24, 201016 yr Nice. Always like seeing Explorer Sport build logs since I have one too. Always helps me with ideas on new stuff.
June 24, 201016 yr "my stuff doesn't even come close to what most of you are doing" Does not matter what you install-Mild or Wild-This forum enjoys all! We do luv the pics, the more the better. You have a great start! Tuned in
June 24, 201016 yr Author Nice. Always like seeing Explorer Sport build logs since I have one too. Always helps me with ideas on new stuff. Sweet! Mine is gonna be pretty basic though. Nothing fancy.
June 24, 201016 yr Your subs look niiiice!Ssd's not Bl's ? Damn !Go ported, you will pound harder! Tuned in for more pics. Thanks for posting.
June 24, 201016 yr Author Your subs look niiiice!Ssd's not Bl's ? Damn !Go ported, you will pound harder! Tuned in for more pics. Thanks for posting.No BL's. lol This is a budget build for sure. Plus, not may people are reppin the SSD's, so I though I would.
June 24, 201016 yr Author Thought I would post a few more pics cause the Black Berry ones are terrible! I should know better.... I'm a photog.... Knuconceptz 0 awg next to their 4 awgThe HUGE Knuconceptz ANL Fuse holder. Sorry, but I laugh every time I look at it, but jealous at the same time. hahaAmpSide 1Side 2 4 gauge power and ground hence the 3rd Fuse holder. 0 into a distribution block, 4 out, fused, then to the amp.That's all for now. More as the rest comes in and I start building and installing on Sunday.
June 29, 201016 yr Author Just an update. Got my shipment in from Sound Deadening solutions today and already used up about half of it in problem area's on the explorer. I also started to build a 2.5 cube common chamber sealed box just to see how bad my wood working skills are. Yup, I pretty much suck! Cant cut a straight line to save my life. I have a jig saw and a skill saw to work with and that's it. Even marking correct and following the line my cuts are wavy to a fault. So I might just jump on the pre-order for the new Khaotik boxes. I think I'll use the rest of the wood to make a false bottom in the cargo area so I can stash the amp away under a door. Pics and more updates coming tomorrow as I'll be working on running wires and other stuff most of the day!
July 2, 201016 yr Author Finally have some time to post pics. VERY slow build process because I own my own business so I work ALL THE TIME! lol I'm also a single parent so that makes it tough too. Anyways, here is what I have been up to this last week.DB Electric Alt. NOT HAPPY. Battery at idle sits at 12.8 volts. Called and the told me the pulley is smaller so use a smaller belt. Check... didn't do a thing. So then I swapped pullies out from the old to the new, nope... didn't help. Brand new belts too. Wasted 33 bucks on a belt I'll never use now. So now I wanna send it back but they are going to charge me a 25% restocking fee.... total bs. My stock alt is 130 amp, so I'm just going to run that one until I have cash to drop on a $400 quality alt.Optima in, big 3 done, power and ground wires all ranStarted building my box today. So I made the kid cut the grass so I could keep working. Craptastic box. Man I suck at cutting straight! Stupid stuff too like cutting on the wrong side of the line, plus the blade width, leaving the piece an 1/8" short. Nothing that a bit of sanding and caulk wont fix. Kinda ghetto but its all I can do.3 sides are done with the top just resting for show. Another viewAll of the inside corner pieces are cut and the back to corners are already glued and caulked. Still need to cut the ports and the holes out of the second baffle before I glue them. If you are wondering this is the ICON dual 12 ported box from the tech section. 4 cubes @ 30 hz with 55 sq inches of port. Hope to finish the rest next week and final get it in the Explorer. And the new box is just sitting on an unfinished sealed box so I don't have to bend over as much. I'm 6'6" so I'm not fond of things on the ground.I also used up all my deadening tiles but I didn't take pics of that. 40 tiles total went in trouble area's. It really made a huge difference in most spots so I am glad I did pick those up. More to come next week I hope and if all goes right I have a video too.
July 3, 201016 yr hey your not the only one with cutting issues lol. i built a new box 4 my fosgate power hx2 15 the other day and i had all my cuts straight until i got to the baffle and the top. i used to double baffle from my previous box and the last cut on it was jacked and the top was a little short. but hey caulk, screws and mdf scraps fixed that. its in a trunk of an ugly ol' car so noone sees it
July 3, 201016 yr Author hey your not the only one with cutting issues lol. i built a new box 4 my fosgate power hx2 15 the other day and i had all my cuts straight until i got to the baffle and the top. i used to double baffle from my previous box and the last cut on it was jacked and the top was a little short. but hey caulk, screws and mdf scraps fixed that. its in a trunk of an ugly ol' car so noone sees itIt's just amazing how I can't build a box to save my life but my buddy and I built his entire house. I didn't have a single issue then. Now I'm like saw handicapped or something?
July 3, 201016 yr Author nice build. what kind of camera do you have that thing is HDThese were taken with a Canon 5d and a Sigma 50mm macro. Here is a partial list of my gear I use.Have a lot more since this list and some upgrades on stuff.Bodies:Canon 40d w/ grip2- Canon 5d w/ grip1d Mark IIRebel XT w/ Grip IR ConversionAE-1 Program w/ several lensesLenses:Tokina 12-24 f/4Canon 17-40LCanon 50 1.8Canon 50 1.4Sigma 50 2.8 macro x2Canon 85 1.8Canon 24-70 2.8LCanon 70-200 2.8LLighting Gear:2- abr800 ring flashes2- Vagabond II Battery packs2- 30" Moon units w/ Mask sets2- 56" Moon units w/ Diffusers2- 20° Honeycomb GridsNumerous Gels for the ringflashMetz 44 flashCanon 430ex flash2- Canon 580EX II flashes2- Vivitar 285HV flashes6- Cybersync Receivers2- Cybersync Transmitters4- 42" Wescott Umbrella's4- 9' Manfrotto Light stands2- Rosco Gel sets3- Flash diffusersFong Lightsphere IIColor flash GelsStability:486RC2 Compact BallheadGiottos M7001 ballheadGiottos MT-9360 LegsBags:domke f1-xLowepro backpackNational Geo Medium should bagComputer:Dell Studio 540Vista x642.33 GHz Quad core ( Q8200 )8 Gb ram512 mb video card640 GB internal HD640 GB internal HD160 GB External HD1 TB External HD2-2 TB External HDPS CS4Lightroom 2.2Lots of plugins and actions22" widescreen LCD monitor19" LCD for CS4 Palettes
July 5, 201015 yr Author Finished the box yesterday and loaded up the subs this morning! Its is storming out right now so i didn't spend a ton of time out with it. Output at first was kinda weak and didn't seem any louder then my 12" Orion on 500 watts. Stood in the rain watching the cone when I noticed one was wired out of phase. So I pulled it, rewired it and stuck it back in. I totally agree with everyone that says these subs are under rated! Output is insane and damn these things move some air. At full tilt on music my eyes jump around so much! VERY happy I went with these subs! Video to come once the rain finally passes, which won't be for a few days.
July 5, 201015 yr Author Quick video via my Black Berry playing a bass song. Camera picks up flex for crap. New video coming tomorrow after I change my JVC up.
