Posted July 3, 201016 yr I just wanted to know if it was possible to make a sonotube enclosure for an 18" fi q. It will be powered by a aq 1200d. I just want to know if it's possible or will the tube flex too much
July 3, 201016 yr if it's sealed it can be done easily, but for a ported box.. it would be huuuge or really weird.
July 3, 201016 yr could take a piece of mdf and do a giant kerf to make a cylinder. i've seen it done but not for an 18. i think it could stand up quite well if u reinforce it with fg inside and build it well. as for a sono tube of that size i have no clue..
July 3, 201016 yr I just wanted to know if it was possible to make a sonotube enclosure for an 18" fi q. It will be powered by a aq 1200d. I just want to know if it's possible or will the tube flex too muchme and shizzzon, recently have done some testing with 12" x 4' concrete form tubes.. If you yell in them or talk in them is has a resonate sound. But Its with 1 15" dc and a 3k AQ, And 5 1/2 cuft net.. and the tube barely flexes.. They wont resonate..as you would think they would... And yes you could do the 18 in one but you would have to make a ring around it to mount it.. also you will have to cut the port a few time to test if it will be possible.Edit- What vehicle do you have? Edited July 3, 201016 yr by Dizzzle
July 3, 201016 yr you will need to resin the tube to support the pressure and using it as an enclosure vs a port is 2 totally different things.You may also need to brace the outside tube in case it wants to flex if fiberglassing the outside doesn't help.
