Posted September 18, 200521 yr Sup guys, i'm really interested in the mags, i know it's goin to cost me some money but def. well worth it, i'm thinking of putting up a wall in my car and go with either 3 12" mags or 4 12" mags, most likey each powered by a nine.1 or an RE 12.1, i was wondering how much space would be recommended for them i'm goin to say probably 2.0 cf per sub? and what would be a good tunning for it, probably around 32-35 hz? its either a wall or 2 12" in a crx style box with a orion 2500d.. suggestions are welcome. thanx
September 18, 200521 yr Sup guys, i'm really interested in the mags, i know it's goin to cost me some money but def. well worth it, i'm thinking of putting up a wall in my car and go with either 3 12" mags or 4 12" mags, most likey each powered by a nine.1 or an RE 12.1, i was wondering how much space would be recommended for them i'm goin to say probably 2.0 cf per sub? and what would be a good tunning for it, probably around 32-35 hz? its either a wall or 2 12" in a crx style box with a orion 2500d.. suggestions are welcome. thanx<{POST_SNAPBACK}>4 subs? wow ur gonna have to replace the windows with a stronger type of glass lol
September 19, 200521 yr Sup guys, i'm really interested in the mags, i know it's goin to cost me some money but def. well worth it, i'm thinking of putting up a wall in my car and go with either 3 12" mags or 4 12" mags, most likey each powered by a nine.1 or an RE 12.1, i was wondering how much space would be recommended for them i'm goin to say probably 2.0 cf per sub? and what would be a good tunning for it, probably around 32-35 hz? its either a wall or 2 12" in a crx style box with a orion 2500d.. suggestions are welcome. thanx<{POST_SNAPBACK}>Honestly if you are only going to use one ED, RE, or orion amp you would be better off running 1 maybe 2 of them. If you had an orion 1200d on each now that would kick. The will get pretty loud with 300 or so watts but if you put 1200 to each with a medium to large upper tuned box you would be sitting pretty. Just my .02
September 19, 200521 yr Author yeah, good point, how bout a 2500d running all 4 which would put the amp at a 1 ohm load, so about 500-600 watts
September 19, 200521 yr yeah, good point, how bout a 2500d running all 4 which would put the amp at a 1 ohm load, so about 500-600 watts<{POST_SNAPBACK}>That would be pretty nice. Are you going for SQL or SPL? SQL I honestly think that 2 12" would be plenty, maybe 2 15" if your feeling froggy. If you are going for SPL the 4 12" would work but Id suggest you get more power. They perform well with low wattage but you might want more to get the full potential out of them.
September 19, 200521 yr Author yeah, i think i'm goin to go with 2 12" and make a crx style box, where the subs face up and the port facing the trunk since i have limited space, or should i got with a single 15"
September 19, 200521 yr HA! How can one even mention SQ or even SQL with 3 or 4 of the nasty buggers???!!!!
September 19, 200521 yr Author ok how bout 2 12" in a 5-6 cf box tuned to 32hz, and both hooked up to an orion 2500d at .5 ohm load, would that be a good combo?
September 20, 200521 yr If you want to compete mainly, that tuning is fine. If you want more of a street beater system, lower tuning into the mid/high 20's. Other than that, the setup you listed sounds really good.
