Alright my RL-p 12 is on its way and now I'm trying to sort out the rest of the things I need. Because of money I am going to get either a Pheonix Gold Xenon 600.1 or a Kicker kx600.1 off ebay for an amp. Any suggestings? Also how and what do I need to wire my sub to my amp? I decided to build a box myself, so for 1 rlp with 600-700 watts at 2 ohms a sealed box should be around 1ft^3? What would be some common dimensions? Finally where is a site that could direct me in going about building a box. Thanks
The Xenon would be a little more "flexible" regarding future use since it's 600w @ 1-4ohm. If that's what floats your boat, go for it. I personally would just go for whatever's cheaper. Both are quality amplifiers.
Speaker wire? Around 8ga to 10ga is what I normally use.
Also some type of terminals on the sub enclosure if you want to be able to quickly disconnect the sub from the amp.
Anywhere from 1cuft - 1.5cuft would be good.
I went with 13.5 x 13.5 x 13.5 internal dimensions. Made things very simple to remember during the box building phase, and works out to be almost exactly 1.25cuft after sub displacement.
What exactly do you need help with there?
I was wondering how do I wire the amp for 2 ohms?
I was wondering about a website that could take me thorugh the step by step of building of a sub box.
Also where could I pick up the materials?
Check out secrets to box building pinned in Competition & Fabrication
on this forum. It helped me out a lot. Local lumber yard, lowes, home depot etc for mdf, glue, etc.
2ohm load with a dual vc 4 ohm driver pos to both pos terminals on driver & neg to both neg terminals on driver.
