Posted July 13, 201016 yr im about to buy a amp for my alpine type r in a few days and its rated at 500rms and i dont know what would be a good amp to power it. my budget is 150$
July 13, 201016 yr You could look into Audiopipe, Powerbass, Planet Audio etc. Kicker refurbs are for sale on eBay for a decent price.Also the classifieds section here would be a good start.
July 16, 201016 yr You'd better look for a 1000 watts amp that is 1 Ohm stable. You will want to upgrade later, for sure :). 500 watts at 2 Ohms for now, and 1000 at 1 ohm for the future. Think about it !
July 17, 201016 yr Author You'd better look for a 1000 watts amp that is 1 Ohm stable. You will want to upgrade later, for sure :). 500 watts at 2 Ohms for now, and 1000 at 1 ohm for the future. Think about it !i bought a alpine mrp-m500 for now and when i get a job i am for sure upgrading to a fi bl 12 and a saz-1000d
July 17, 201016 yr You better watch what you play on that and listen very close to the sub for bottoming out.That amps SSF is set at 15hz and playing below your box tuning will smoke that sub in short order.
July 17, 201016 yr Author You better watch what you play on that and listen very close to the sub for bottoming out.That amps SSF is set at 15hz and playing below your box tuning will smoke that sub in short order.what does bottoming out sound like?
July 17, 201016 yr You better watch what you play on that and listen very close to the sub for bottoming out.That amps SSF is set at 15hz and playing below your box tuning will smoke that sub in short order.what does bottoming out sound like?i see a blown woofer in your future....It sounds like metal hitting metal http://www.youtube.com/watch?v=GaHo9s6nrGMyou can hear it at the 11 to 13 second mark
July 17, 201016 yr Author ok i will look out for that and it will probably blow but i couldn't really find a amp in that price range with a adjustable subsonic filter. alpine said this amp was made for the type r so idk we will see
July 17, 201016 yr Author For that budget - Audiopipe? The answer was right there.x2 on the Audiopipe.i didnt see that post til after i already bought the amp
