Posted July 13, 201016 yr Eyh, Got a great deal on dual DD3515 2ohm dvc subs, so i'm planning on running them at 2 ohms, Been looking at the kicker 2500.1 amp but is there any more good altarnatives out there ?Thanks, Denven
July 13, 201016 yr You could strap two 1000-1500 watt @ 1 ohm amplifiers, like the Sundown SAZ-1000D, etc. What is your price range?
July 13, 201016 yr Author Price range is between 600$ - 800$. would be better with 1 amp, but will go for the best alternative tho =)
July 13, 201016 yr hey i would vote for 2-SAZ1000d amps! those things are beasts! and when you strap them the require a 2ohm load and can output more then 2000rms! i used to have a pair i know how they work and they work very awesome and efficiently! hands down! here is a link on ebay for some bnib ones! and if you pop over to db-r you can get a better deal (if he has some there for sale)http://cgi.ebay.com/Sundown-Audio-SAZ-1000D-Class-D-Amplifier-1000-WATTS-/180531157308?cmd=ViewItem&pt=Car_Amplifiers&hash=item2a087ed93c#ht_2296wt_1137
July 13, 201016 yr KICKER ZX-2500.1http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160451567952&rvr_id=&crlp=1_263602_263622&UA=WXF%3F&GUID=b9d35aec1290a0e20357a497fd5ac35e&itemid=160451567952&ff4=263602_263622
July 13, 201016 yr Why would u guys recommend 2 amps for him? There are quite a few of negative points on using 2 amps.1) 2 amps usually need more current.2)You need double the amount of wire.3)You have 2 bass knobs.(or else you need to modify a bass knob.)There are also a few advantages: Easier to hide the amps.Just seen that 2 of the SAZ1000 are cheaper.So i would do those two. But i would recommend the single amp for him.You can get a Sundwon SAZ-2000(if they are out already) or a SAZ-2500.Or even a Rockford Fostgate 2500.1.(but i don't know if that fits in you're price range.)But the kicker is also a good amp. Edited July 13, 201016 yr by kirill007
July 14, 201016 yr Why would u guys recommend 2 amps for him? There are quite a few of negative points on using 2 amps.1) 2 amps usually need more current.2)You need double the amount of wire.3)You have 2 bass knobs.(or else you need to modify a bass knob.)There are also a few advantages: Easier to hide the amps.Just seen that 2 of the SAZ1000 are cheaper.So i would do those two. But i would recommend the single amp for him.You can get a Sundwon SAZ-2000(if they are out already) or a SAZ-2500.Or even a Rockford Fostgate 2500.1.(but i don't know if that fits in you're price range.)But the kicker is also a good amp. 1) Not necessarily. One amp at 80% efficiency is exactly the same as two amps at 80% efficiency.2) Not double. You can still do one run of 1/0 or similar to the back, then use a distribution block to go to the two amps. All you'd need is an extra couple feet of each wire.3) No. If you strap amps, you only use one amp as the master, and that controls the output of both amps. Thus only one bass knob is needed.SAZ-2000 and SAZ-2500s both do optimum power at 1 ohm. Cut it in half (or 1000-1500) for a 2 ohm load.
July 14, 201016 yr Why would u guys recommend 2 amps for him? There are quite a few of negative points on using 2 amps.1) 2 amps usually need more current.2)You need double the amount of wire.3)You have 2 bass knobs.(or else you need to modify a bass knob.)There are also a few advantages: Easier to hide the amps.Just seen that 2 of the SAZ1000 are cheaper.So i would do those two. But i would recommend the single amp for him.You can get a Sundwon SAZ-2000(if they are out already) or a SAZ-2500.Or even a Rockford Fostgate 2500.1.(but i don't know if that fits in you're price range.)But the kicker is also a good amp. Why would u guys recommend 2 amps for him? There are quite a few of negative points on using 2 amps.1) 2 amps usually need more current.2)You need double the amount of wire.3)You have 2 bass knobs.(or else you need to modify a bass knob.)There are also a few advantages: Easier to hide the amps.Just seen that 2 of the SAZ1000 are cheaper.So i would do those two. But i would recommend the single amp for him.You can get a Sundwon SAZ-2000(if they are out already) or a SAZ-2500.Or even a Rockford Fostgate 2500.1.(but i don't know if that fits in you're price range.)But the kicker is also a good amp. 1) Not necessarily. One amp at 80% efficiency is exactly the same as two amps at 80% efficiency.2) Not double. You can still do one run of 1/0 or similar to the back, then use a distribution block to go to the two amps. All you'd need is an extra couple feet of each wire.3) No. If you strap amps, you only use one amp as the master, and that controls the output of both amps. Thus only one bass knob is needed.SAZ-2000 and SAZ-2500s both do optimum power at 1 ohm. Cut it in half (or 1000-1500) for a 2 ohm load.On top of all that, he needs his power at 2ohms. Most of the nice amps normally recommended wouldn't cut it due to them doing power at 1 ohm.Look out for the new SAX-1200 as well. It's strapable and from the looks of it outperforms the SAZ-1000D.
July 14, 201016 yr Author Thanks for all the replies, got a few options now atleast, will see what i will go with, also the tought of resell value as well, sundown amps in Norway is quite rare, pluss the kicker 2500.1 is really expensive here than US even with the 25% tax of the price when importing it from US. so will see what i go with, still a bit while till i install my system, need ofc the power to run it as well hehe. thinking about 137ah of batteries and 180A or 200A alt should do it and the big 3 which i've already done :>
July 14, 201016 yr Why would u guys recommend 2 amps for him? There are quite a few of negative points on using 2 amps.1) 2 amps usually need more current.2)You need double the amount of wire.3)You have 2 bass knobs.(or else you need to modify a bass knob.)There are also a few advantages: Easier to hide the amps.Just seen that 2 of the SAZ1000 are cheaper.So i would do those two. 1) Not necessarily. One amp at 80% efficiency is exactly the same as two amps at 80% efficiency.2) Not double. You can still do one run of 1/0 or similar to the back, then use a distribution block to go to the two amps. All you'd need is an extra couple feet of each wire.3) No. If you strap amps, you only use one amp as the master, and that controls the output of both amps. Thus only one bass knob is needed.SAZ-2000 and SAZ-2500s both do optimum power at 1 ohm. Cut it in half (or 1000-1500) for a 2 ohm load.That why i used strikethrough, because the 1 amp option was wrong. ><Damn, i don't know what i was thinking yesterday. probably a few too much of these:
July 14, 201016 yr Price range is between 600$ - 800$. would be better with 1 amp, but will go for the best alternative tho =)check out soundstream rubicon amps .. good amps
July 14, 201016 yr Price range is between 600$ - 800$. would be better with 1 amp, but will go for the best alternative tho =)check out soundstream rubicon amps .. good ampsNo. He needs an amp that puts out 2500 watts at 2 ohms not 1 ohm.
July 14, 201016 yr Price range is between 600$ - 800$. would be better with 1 amp, but will go for the best alternative tho =)check out soundstream rubicon amps .. good ampsNo. He needs an amp that puts out 2500 watts at 2 ohms not 1 ohm.ah k Thats a tough one for money that low.. Edited July 14, 201016 yr by BASSnoob
