Posted July 29, 201016 yr 4x Incriminator Audio Death Penalty 21" non wall running from a ZED Audio Leviathan bridged, about 300w/woofer. Will upgrade to bigger amps, and make another movie again!
July 30, 201016 yr is that a civic? next vid do it with the doors shut and windows up so we can see some real flex
July 30, 201016 yr At first, I was like But then I was likewhen I saw how much power you were running
July 30, 201016 yr Author Another videohttp://www.youtube.com/watch?v=WgGwpBLGBac&feature=relatedThe car is a Opel Astra -93
August 1, 201016 yr If hi doesn't get the amps soon Im thinking to go over there and put my M3 on them @ .5 ohm se what happens should get 2.5-3kw out of it ore maybe 2 M3´s i want to se some real flex Edited August 1, 201016 yr by bogdis
August 1, 201016 yr nice but u know that d sunroof is gona go bye bye seal that shit off ...and put some MDF up
August 23, 201015 yr Author First test, running about 800-900w/subClosed doors, closed trunk, 144.0db@51HzOpen trunk open doors, 143,7dbOpen trunk, closed doors 147.1dbOpen trunk, open drivers door
August 23, 201015 yr whats with only drivers door open ? and the subs need more juice ...way more Edited August 23, 201015 yr by Tyan
August 25, 201015 yr Looking at the TL numbers I see that you have some SERIOUS cancellation issues in your car. I would DEFINITELY recommend that you try a different sub/port (Most likley port) placement.
