Posted August 7, 201016 yr Does any of Second Skins products cut down on plastic that rattles? It seems my door panels vibrate and rattle the most and is getting annoying, so I thought I would ask what would be the best product to coat my inside plasitc door panels with? If anything hahah.
August 7, 201016 yr Maybe you can try to put something (like a clothe, or a piece of rubber, plastic,...!?) Behind the panels that vibrate. It will keep them tight on the body of the car. You must find where do the panels move and hit something. Then you stop each noise, one by one. I've started to do that in my car : not easy, but works.
August 9, 201016 yr rattle pad or overkill/overkill pro on the places it touches the door. possibly damp pro otherwise but the foam is what does most of the work
August 9, 201016 yr Author Ok thanks a lot guys! Ill try some of closed cell foam when I order some deadener and well see how it works out.
