Posted August 13, 201016 yr This is yet another build for my good friend. Seems he has to buy a new truck every year or so... What's Going in:2 Massive Audio DB8000 Amps 8000w @ 1 ohm strapped (the two amps will be strapped and running 1.33ohm)1 Massive Audio HD1600.4 200w x 4 @ 2 ohm 1 Soundstream Ref Comp set 6.5" (something used I had sitting around that he liked)3 Rival Mobile Electronics A12.22 4" VC D2 ohm 2000w RMS2 Shruiken BT120'sJVC Deck--nothing fancy 1/0 everywhere... big 3 ect...all tsunami cables**not sure on the rear speakers yet... they're not all that important... he's got some old soundstream 6x9's that we'll probably stuff in there.. Edited August 13, 201016 yr by rushnrun
August 13, 201016 yr Author GuttedRCA's and speaker wires all loomed up*note that I hand washed the entire floor... A little deadener... cheap stuff... just what I had sitting around.*all these photos are pre- heatgun/roller... just laid down in the picsCarpet Pad__removed them and washed them up.. they were pretty nasty.. the carpet was all stained up.. some oxyclean and scrubbing took care of the carpet..cd wiring, soldered and heat shrinkedall the wires... *we didn't clean the cargo carpet... yet...going back togetherapparently I didn't get any pics of the door speaker install.. pretty basic.. mids and highs are in factory location..I'll get some box build pics posted later today or tomorrow.
August 17, 201016 yr Author here's some early pics of the box... it's further along now I just need to upload the other pics... these are off my cell
August 17, 201016 yr Author Is that electrical setup going to be sufficient?It's two bt120's in the rear and we're working on adding two more under the hood.. with his resting ohm at 1.33 we'll probably only see 6000watts out of the pair of amps most of the time... (between the box rise and resting load being a little high.) *high output alt will be added as well... just at a later time... probably closer to winter.. **this won't be up and running for atleast 3-4 more weeks...
August 17, 201016 yr Author Lookin' Good!!!! Those 12's gonna be sealed?ported... 6 cubes net tuned 32-33hz... More pics coming in a few
August 17, 201016 yr Author clamping on the 1" worth of spacer to bring the subs back.test fitting the partsactually gluing the port/battery tray downunderside.... ignore the scribbles... baffle... glass drying...
August 18, 201016 yr Great work!!! Im interested in seeing some door pics. I know you said it was pretty basic but I would love to see them if you took any pics
August 18, 201016 yr Author We failed to take any pics of the doors... when we take them back apart we'll have to get some photos...
August 18, 201016 yr Sorry about my previous question about the enclosure. Pics made it a little hard to see, but wow that looks awesome! Can't wait to see more!
August 18, 201016 yr Author Sorry about my previous question about the enclosure. Pics made it a little hard to see, but wow that looks awesome! Can't wait to see more! I know... my cell takes REALLY Terrible pics... sorry More will be done tomorrow... there's still a ton to do.. this has to be put on hold a bit since I have two other boxes to build for customers... (this Yukon build is for a good friend so the "regular" customers take priority) I'll work on it a little for the next two days but I really have to focus on the other two builds--One is big (like this one) and the other is just a basic box.
August 19, 201015 yr Author the way it is as of yesterday... baffel mounted... the top board is just sitting there... that's not where it belongs**this thing is now too bulky/heavy to move on my own
August 22, 201015 yr Author Got all the seems glassed up with 2-3 layers of mat...get some more pics monday..
August 22, 201015 yr I bet it is heavy, that thing is a beast!! Lookin' great!! Can't wait till monday.
August 24, 201015 yr Guess you had some " "regular" customers take priority" work to do. I was lookin' forward to an update today.
August 24, 201015 yr Author Guess you had some " "regular" customers take priority" work to do. I was lookin' forward to an update today. yeah... sorry... updated being posted in a sec ***and by the way.... I posted this up with the wrong truck details... his old truck was the 96 yukon... this is a 99 two door Tahoe
August 24, 201015 yr Author Did some glassing Yesterday... Put the top ontrimmed up the top today...opened up the port as well--still have finish work to do in there.. I'm holding off until I get the flare glassed--it's an addition to the top of the box. no sense in doing a ton of sanding now when resin is bound to drip down there later..test fitting the amps... getting an idea of the wiring layout ect...
