Posted August 13, 201015 yr I am buying this box and want to know which Fi sub will sound best in this encolsure. I want the best output/best sound combo for 1 12" or 10" I have about 300 watts of clean old school AB power that I will be pushing it with. Here is the link to the enclosure.Subthump Edited August 13, 201015 yr by tb69396
August 13, 201015 yr I am buying this box and want to know which Fi sub will sound best in this encolsure. I want the best output/best sound combo for 1 12" or 10" I have about 300 watts of clean old school AB power that I will be pushing it with. Here is the link to the enclosure.SubthumpI say forget that box and build your own. Using a prefab with any fi sub is just asking for trouble. As for the sub, based on your amp, I'd say the fi x or maby the ssd
August 13, 201015 yr Author I am buying this box and want to know which Fi sub will sound best in this encolsure. I want the best output/best sound combo for 1 12" or 10" I have about 300 watts of clean old school AB power that I will be pushing it with. Here is the link to the enclosure.SubthumpI say forget that box and build your own. Using a prefab with any fi sub is just asking for trouble. As for the sub, based on your amp, I'd say the fi x or maby the ssdI keep hearing this about a prefab box, but even if I built one it would not be any different. There is no room back there and I need the seat.
August 13, 201015 yr I am buying this box and want to know which Fi sub will sound best in this encolsure. I want the best output/best sound combo for 1 12" or 10" I have about 300 watts of clean old school AB power that I will be pushing it with. Here is the link to the enclosure.SubthumpI say forget that box and build your own. Using a prefab with any fi sub is just asking for trouble. As for the sub, based on your amp, I'd say the fi x or maby the ssdI keep hearing this about a prefab box, but even if I built one it would not be any different. There is no room back there and I need the seat.The shape wouldent be diferent, it's about the quality of how it's built. Almost all prefabs arenot made well at all. Heck, some don't even use mdf. I got a prefab for a 12 a year or two back and had 200 watts on the sub and the side broke loose after a week.
August 13, 201015 yr Author I am buying this box and want to know which Fi sub will sound best in this encolsure. I want the best output/best sound combo for 1 12" or 10" I have about 300 watts of clean old school AB power that I will be pushing it with. Here is the link to the enclosure.SubthumpI say forget that box and build your own. Using a prefab with any fi sub is just asking for trouble. As for the sub, based on your amp, I'd say the fi x or maby the ssdI keep hearing this about a prefab box, but even if I built one it would not be any different. There is no room back there and I need the seat.The shape wouldent be diferent, it's about the quality of how it's built. Almost all prefabs arenot made well at all. Heck, some don't even use mdf. I got a prefab for a 12 a year or two back and had 200 watts on the sub and the side broke loose after a week.This one is made of 3/4" MDF. Looks like it is built well enough and its cheap. So if it is made well, which sub would sound best in it?
August 13, 201015 yr I am buying this box and want to know which Fi sub will sound best in this encolsure. I want the best output/best sound combo for 1 12" or 10" I have about 300 watts of clean old school AB power that I will be pushing it with. Here is the link to the enclosure.SubthumpI say forget that box and build your own. Using a prefab with any fi sub is just asking for trouble. As for the sub, based on your amp, I'd say the fi x or maby the ssdI keep hearing this about a prefab box, but even if I built one it would not be any different. There is no room back there and I need the seat.The shape wouldent be diferent, it's about the quality of how it's built. Almost all prefabs arenot made well at all. Heck, some don't even use mdf. I got a prefab for a 12 a year or two back and had 200 watts on the sub and the side broke loose after a week.This one is made of 3/4" MDF. Looks like it is built well enough and its cheap. So if it is made well, which sub would sound best in it?You can't base quality on how somthing looks. The box I got, but faild looked well built, but it wasn't. An I can't tell you how it will sound, it's all install dependent. it's up to you what you want to do, I would just not trust a prefab box like that. There are always places like argent audio that Build nice boxes. They make great stuff as I have seen. Edited August 13, 201015 yr by Bobobass
August 13, 201015 yr Author I am buying this box and want to know which Fi sub will sound best in this encolsure. I want the best output/best sound combo for 1 12" or 10" I have about 300 watts of clean old school AB power that I will be pushing it with. Here is the link to the enclosure.SubthumpI say forget that box and build your own. Using a prefab with any fi sub is just asking for trouble. As for the sub, based on your amp, I'd say the fi x or maby the ssdI keep hearing this about a prefab box, but even if I built one it would not be any different. There is no room back there and I need the seat.I emailed Argent to see if they could make me something custom. It seems everyone around where I live quit doing custom work and unless I want to spend a lot of time designing, which I don't have, I may end up with a pre-fab. Hopefully Argent says they can.The shape wouldent be diferent, it's about the quality of how it's built. Almost all prefabs arenot made well at all. Heck, some don't even use mdf. I got a prefab for a 12 a year or two back and had 200 watts on the sub and the side broke loose after a week.This one is made of 3/4" MDF. Looks like it is built well enough and its cheap. So if it is made well, which sub would sound best in it?You can't base quality on how somthing looks. The box I got, but faild looked well built, but it wasn't. An I can't tell you how it will sound, it's all install dependent. it's up to you what you want to do, I would just not trust a prefab box like that. There are always places like argent audio that Build nice boxes. They make great stuff as I have seen.
August 13, 201015 yr Author a X would work fine..you've only got a little bit of power I think its funny that back in the day I ran a Lanzar Plus 100 to two Soundstream Reference SS10's and killed it with SPL and SQ. Cheater amps were great. If I really need more power than my Lanzar 240 I can always pull out my super old Lanzar 600. I think it was made in 1986 or so. 0.015% distortion at 4 ohms. Pure sound.
August 14, 201015 yr Author I don't know what happened to my post up there but i was trying to say this.I emailed Argent to see if they could make me something custom. It seems everyone around where I live quit doing custom work and unless I want to spend a lot of time designing, which I don't have, I may end up with a pre-fab. Hopefully Argent says they can.
August 21, 201015 yr Just build ur own box anything besides mdf ain't worth it plus u cnt just put a sub in a box and hope it bumps literly bro it's 5% equipment and 95% install so don't go off thinking it's right cuz like **** one guy sed it's just askin for trouble..do some research on wuts best for ur sub and ur car you'll come across something that suits u goodluck bro
