Posted October 2, 200520 yr Hey what's up. I just got into the car audio scene because I just got a '06 Scion tC and want to upgrade the sound. In my old car I had an Eclipse head unit, MBQuart components in front and back, and an MTX amp powering it on. I didn't do much research...just went to CarToys and picked out what i liked in my price range. In my tC I plan on dropping a sub...so I've been doing a good deal of research through forums. I found this forum when a member referred me to it. I want to gain knowledge through you guys and share whatever I have learned myself on the way. So far I have picked out an amp but I'm still having a hard time figuring out what sub I should get. Any suggestions will be greatly appreciated.Other than that, I'm 19 go to UT Austin, parents live in Ft Worth. I was once studying for a mechanical engineering degree but I now hate college and see it as a waste of time as much much much more money can be made through investing, stocks, and the like. I'm also into the whole Home Theater scene...I just purchased a projector and will be getting an audio system setup. I also play World of Warcraft but lately haven't because I got a job finally and well it gets boring after you've done most everything in the game.This forum doesn't seem like the other ones that are plagued with idiots that would rather flame than help each other out. I look foward to being a part of this community. Anyways it's 4:30 am and I need to sleep
October 2, 200520 yr Looks like you have somewhat of an idea on what you want for your Scion.I think 2 members on this site have them aswell.For a sub we need to know the following:What kind of music do you listen toWhat type of sound do you like: SPL or SQDo you have an amp alreadyWhat is your budget.Answer those and we might be able to find you something sutable for your needs.
October 2, 200520 yr Author Looks like you have somewhat of an idea on what you want for your Scion.I think 2 members on this site have them aswell.For a sub we need to know the following:What kind of music do you listen toWhat type of sound do you like: SPL or SQDo you have an amp alreadyWhat is your budget.Answer those and we might be able to find you something sutable for your needs.<{POST_SNAPBACK}>Thank you for the welcome I listen to metal, rap, hard rock, alternative, trance(mostly progressive), r&b. SQ matters a lot to me...but I'm a basshead and want to be able to feel the bass pounding in my lungs when I want. Whenever I look at a sub I make sure it can hit atleast 20Hz if not 16 Hz. But it looks like I will have to compromise in car audio as those subs usually need a much bigger box than the 2 cu ft that I want to limit my box to. So I would like the bass to be atleast 30Hz or below at -3dB. But will compromise more if I realllly need to. I have a Pioneer Premier PRS-X720 amp. It's rated at 400W RMS @ 4 ohm but its birthsheet has it rated at a little over 800@ RMS @ 4 ohm. It is very common for the amp to have double its rated output. I don't want to run the amp at max so I'm trying to limit the wattage I use to 700. My budget...well for the time being I'm trying to spend less than $200 on the sub and I dunno $50 on a box. I want a 12" sub...I don't have the room for a 15".I spent a lot of time on sounddomain, elite car audio, car audio, and car audio forums gathering information. The subs I considered are:IDMAXOZ Audio Matrix EliteResonant Engineering SEInfinity Perfect 12.1Dayton MKIIIDayton High FidelityElemental Designs OV lineW3Alpine Type RKicker CompO Audio TC2+HSU ASW-1203Soundsplinter rl-pThe subs I am still considering:Dayton MKIIIDayton High FidelitySoundsplinter rl-pIDMAXOZ MEAlpine Type RI am leaning heavily towards the Dayton HF...but slowly but surely going to the rl-p. I'm a very number based persons as I can't really hear the subs and 97% of the people I've talked to haven't heard the Daytons...I'm hoping to find someone that has heard the Dayton MKIII and/or HF AND the rl-p. That will help me make my decision a great deal.
October 2, 200520 yr The OZ matrix and ID MAX are almost the same sub.I would go with the RL-p simply because of the GREAT customer service that Mike offers and it also requires a fairly small encolsure compared to its rivals.No music will play as low as 20hz so I dont see why thats such a big deal to you. The SSF will cut that frequency anyways.
October 2, 200520 yr Author The OZ matrix and ID MAX are almost the same sub.I would go with the RL-p simply because of the GREAT customer service that Mike offers and it also requires a fairly small encolsure compared to its rivals.No music will play as low as 20hz so I dont see why thats such a big deal to you. The SSF will cut that frequency anyways.<{POST_SNAPBACK}>So is 20Hz just a Home Theater thing? How low should I aim for then for the lowest possible extension in music(well rap I suppose)?
October 3, 200520 yr Welcome to SSA!!!Rock is usually in the 35-45 range and 35 is really being generiousRap is usually in the 30-40 rangeBass music is ~20+ usuallyIt really depends on what your box preferences are. 20hz in a sealed box is no prob (depending on the setup)20hz ported can be a problem if you get too far below the tuning frequency.I still like the IDmax, RL-P, or SI magAny of the 3 would make an excellent SQL sub.
October 3, 200520 yr Author I think the SI Mag is a lil out of the budget.....no ?<{POST_SNAPBACK}>The dude I'm buying my amp from is also selling a D2 for less than $200. I think I'm gonna pick it up. I've been reading about the D2 and researching and it looks sweeeeeet.
October 3, 200520 yr Author Welcome to SSA!!!Rock is usually in the 35-45 range and 35 is really being generiousRap is usually in the 30-40 rangeBass music is ~20+ usuallyIt really depends on what your box preferences are. 20hz in a sealed box is no prob (depending on the setup)20hz ported can be a problem if you get too far below the tuning frequency.I still like the IDmax, RL-P, or SI magAny of the 3 would make an excellent LSQ sub.<{POST_SNAPBACK}>Thanks for the welcome. What exactly do you mean by Bass music?
October 3, 200520 yr Welcome aboard.Justin probably means music like Bass Mekanik, Euphoric Midnight Bass, et al...stuff designed to give your subbass setup a workout.
October 3, 200520 yr Welcome aboard.Justin probably means music like Bass Mekanik, Euphoric Midnight Bass, et al...stuff designed to give your subbass setup a workout.<{POST_SNAPBACK}>Absolutly.
