Posted August 24, 201015 yr So I've seen a ton of videos featuring hair tricks and I figured it'd be cool to see if my system can pull it off..Only problem is that I'm clueless how to go about it. Obviously someone with long hair is needed. I'm not sure what song would be best, or what window for that matter...Any tips for me? Is it pretty much just trial and error? Any reason my system wouldn't be able to hair trick?Does hairspray\hairgel have a negative impact on it? Edited August 24, 201015 yr by Mr. Bojangles
August 24, 201015 yr LOL, just try it and see man. If you can see your shirt blowing around on a song there is a pretty good chance you can pull off a hair trick.
August 24, 201015 yr i doono about how to do it but i can make shirts move pretty good though my driver window with the sunroof open and i have 1 12" btl on a saz2000d so i would think i could do one and hairspray would make it harder due to stiffening of the hair makes it harder to move
August 25, 201015 yr You have 6 10's right? You should be able to do one. That has got to move alot of air
August 25, 201015 yr Best way to do a hair trick?Lots of cone area, lots power power, low notes, in a small space.
August 25, 201015 yr Best way to do a hair trick?Lots of cone area, lots power power, low notes, in a small space. This^^^
August 25, 201015 yr Admin You might need more power for this...Just give it a try though, you never know.
August 26, 201015 yr blondes, or girls with really fine hair, not like thick or full if that makes sense.
August 26, 201015 yr Search for thread "Key to hair trick" or something like that, here on this forum.
August 28, 201015 yr All windows closed, but the one w/the girl standing in front of it. My friend, Hanks truck, complete w/hair trick. Oh yea, and uh.... 48 10" subs off of 12 SAZ-1500's.
