Posted September 9, 201015 yr Hey everyone wanted to let you know the subs are almost here, and they are finished! They turned out great and below is the actual pictures. Last Chance to Preorder! D2 and D4 Available, once they arrive they will be sold only at MAPPreorder Pricing - $140 ea shipped in lower 48Rated Power Handling : 600 Watts RMSMotor Depth : 85mm (~3.34") and a 12" 12 Spoke Frame (~3.25" Deep) = Total Depth ~6.6"Spider : Dual Layer High % Nomex Content Progressive Spider 50mm WW on a 2.5" Diameter Former. Spider on production model is relatively stiff. Available in.. : D2 and D4 Model'sEnclosure RecommendationsPorted : 1.75 CuFt Per Driver after displacement of sub. Tuned ~36hzSealed : .8-.9 CuFt Per Drive after displacement of sub. Unique Cooling SystemThis Subwoofer has a unique voice coil air flow system with no vent flaring on the back plate. Instead, Jacob designed a system in which the top of pole has an enormous flare and the coil former has vent holes. This creates a nice flow patern through the holes and out the pole (vent). This allows less machining when making the sub and works very well! That system combined with a chrome finish allows for a much prettier finish then most driver's!The VVX-12 has a progressive suspension to help prevent mechanical damages. This includes a triple joint re-enforcement ring to hold this joint strongly together at pretty much any power level you throw at them!The VVX-12 Is a great daily driver and will work well in both sealed and vented enclosures. While the driver was tested in both sealed and ported enclosures pre-production, it shined in the vented enclosures on around 600 Watts continuous power. We threw more power then rated at this driver for an extended period of time and it held up without breaking a sweat!Fms : 22.1HzRes : 101.8 Re : 3.8 Qms : 4.57Qes : 0.45Qts : 0.41Rms : 10.0 Kg/sCms : 0.16 mm/NMms : 330.8 grNref : 0.14%Bl : 19.8SPL : 83.3 dBVAS : 59.2 LRp : 33.3 Lp : 60.0 mHCp : 1126.1 uFLe : 3.37 mH Edited September 9, 201015 yr by Skar
September 9, 201015 yr Author Looks like a beast for 600 watts We really wanted our customers to be able to push them hard all the time . I have noted several times that although rated for 600 RMS they won't break a sweat running at that power and a bit higher really. Really can't wait to get some big installs done and see how they perform on different power levels for a certain period of time. Although I am looking forward to getting the 4 installed in the Ford 500, kovemaster is doing 16 in a F-150 that I am dying to see complete!
September 9, 201015 yr Definately solid looking subs. Whats the MAP going to be, and will you have will call in Tampa so they can be picked up instead of shipped? Edited September 9, 201015 yr by PHATBOi
September 9, 201015 yr Author I like the look !Waiting for some (independant) reviews:popcorn:.We will have local shops around Tampa carrying them so you can use that option .MAP Will be $179 as of right now, if something changes I will make note of it.
September 9, 201015 yr I hate not living in the US.140 dollar's for that kind of sub is just low, really low.
September 9, 201015 yr Author I hate not living in the US.140 dollar's for that kind of sub is just low, really low. I will ship it international at a great price PM me
September 9, 201015 yr Sorry, but i'm not looking at a 12 inch sub with a (conservative) 600W RMS rating. (but if i or some friends need it i will certainly remember it. )EDIT: by the way i live in Belgium. Edited September 9, 201015 yr by kirill007
September 9, 201015 yr Author Sorry, but i'm not looking at a 12 inch sub with a (conservative) 600W RMS rating. (but if i or some friends need it i will certainly remember it. )EDIT: by the way i live in Belgium.Haha ok no problem sir.
September 10, 201015 yr I like the look !Waiting for some (independant) reviews:popcorn:.helloi pre ordered these way back in july i can do a review ill make a video of itits going to be 4 of these in a vented box brutus 2608 amp
September 12, 201015 yr nice the logo adds alot to it. . . . the vvx-12 printed on the cone adds a little extra sumthin to it.....i likey lol
September 12, 201015 yr These twelves look like they are made to be above most. im ready to beat them. thanks for the good customer service,
September 12, 201015 yr Author Can't wait to get the preorders out to the customers and get some video's and reviews up .
September 20, 201015 yr Give us the perfect ported box build sheet with a slot port and no more than 14 inches in height. I want to get it built before the sub arrives, also have a crossfire bmf1000d to power this bad boy, can't wait.
September 21, 201015 yr Author Give us the perfect ported box build sheet with a slot port and no more than 14 inches in height. I want to get it built before the sub arrives, also have a crossfire bmf1000d to power this bad boy, can't wait.I will post one tonight or tomorrow for you . Crazy busy over here
September 22, 201015 yr Thanks Kevin, I can't wait, please use a slot port design as it will be the easiest to build. I will review the speaker once I get it and get a chance to break it in properly Also I don't see the xmax listed on the driver, what can we expect in milimeters of xmax? Edited September 22, 201015 yr by smokinkane
September 23, 201015 yr Author Thanks Kevin, I can't wait, please use a slot port design as it will be the easiest to build. I will review the speaker once I get it and get a chance to break it in properly Also I don't see the xmax listed on the driver, what can we expect in milimeters of xmax?Sorry about not posting the box yet, crazy busy over here . I will get it up asap. Xmaxx 21mm one way Edited September 23, 201015 yr by Skar
October 9, 201015 yr Author The boat will arrive October 18th, that is the official day to mark in your calendar . Sorry about all delays, very unusual.
