Posted September 12, 201016 yr is there anyway i can get 6 10's to fit on box thats 30x24 tried using the google sketch and stuff to make box and move around the circles and see but i cant use the program worth a crap lol can anyone help me out here
September 12, 201016 yr Author your giving two dimensions, what abut the third?third shouldn't matter depth is not a issue just wondering if theres enough area on the top to mount them but it is 24" high if you need it
September 12, 201016 yr Just do some math. 101010101010you would need approx 33w and 22 tall but thats the absolute min.You might be able to stagger the two canter holes down a hair and make it work since you only have 30in wide.
September 13, 201016 yr negative on the 30x24. which dimension is more flexible, the 30 or the 24? like mentioned, if you bump the 30" to 33" it could work, or the 24" to 28.5". sketchup confirmed
September 13, 201016 yr Author Thank you scott that is what i was needing done looks like i have find someone to make me something custom i remeasured and the most i could get was 31 or 26
September 13, 201016 yr The third dimension does matter as there is no golden rule that says that all the drivers have to be all on the same face.
