Posted September 13, 201016 yr Ok I dont understand how the guy from the tahoe is running 12 tweeters from one T600.2?Yes I also dont understand how two 1000.4 amplifiers are running ten 6.5inch speakers, two 4inch midranges and two 8inch midbassCan somebody tell me how is that wired? doesnt so many speakers on each channel cause the impedance to be insanely low causing the amp overheat or inestability?am I missing something here?
September 13, 201016 yr it depends the ohmage can be so low or pretty high but he most likely has it at 2 ohm but i can run 100 woofers to 1 amp and not have a problem as long as it is in the right impedance for the amp.
September 13, 201016 yr What ohm are the tweeters?If they are 8ohm....he can run 6 too each channel parrellel and be at 1.3ohm.
September 13, 201016 yr Ok I dont understand how the guy from the tahoe is running 12 tweeters from one T600.2?Yes I also dont understand how two 1000.4 amplifiers are running ten 6.5inch speakers, two 4inch midranges and two 8inch midbassCan somebody tell me how is that wired? doesnt so many speakers on each channel cause the impedance to be insanely low causing the amp overheat or inestability?am I missing something here?Your missing the ability to series speakers together instead of parallel.
September 13, 201016 yr Ok I dont understand how the guy from the tahoe is running 12 tweeters from one T600.2?Yes I also dont understand how two 1000.4 amplifiers are running ten 6.5inch speakers, two 4inch midranges and two 8inch midbassCan somebody tell me how is that wired? doesnt so many speakers on each channel cause the impedance to be insanely low causing the amp overheat or inestability?am I missing something here?Your missing the ability to series speakers together instead of parallel.Yes, he is. It may also be a series-parallel circuit.
September 13, 201016 yr Ok I dont understand how the guy from the tahoe is running 12 tweeters from one T600.2?Yes I also dont understand how two 1000.4 amplifiers are running ten 6.5inch speakers, two 4inch midranges and two 8inch midbassCan somebody tell me how is that wired? doesnt so many speakers on each channel cause the impedance to be insanely low causing the amp overheat or inestability?am I missing something here?Your missing the ability to series speakers together instead of parallel.Yes, he is. It may also be a series-parallel circuit.That's what I'm thinking, get it somewhere close to 2ohm per channel.
September 13, 201016 yr Author Ok I understand you can run series and parallel, but I thought that only applied to subs (where dual voice coils come into action)?Dont tweeters have only 1 negative and 1 positive?. So how can you pick whether to run in parallel or series?The only thing that comes to mind is this: AMP->Tweeter->Tweeter->Tweeter-Tweeter->TweeterA tweeter is connected to the other one, then the other, then the other until the final one reaches the amp. Is this right?
September 14, 201016 yr Ok I understand you can run series and parallel, but I thought that only applied to subs (where dual voice coils come into action)?Dont tweeters have only 1 negative and 1 positive?. So how can you pick whether to run in parallel or series?The only thing that comes to mind is this: AMP->Tweeter->Tweeter->Tweeter-Tweeter->TweeterA tweeter is connected to the other one, then the other, then the other until the final one reaches the amp. Is this right?You can series anything with voice coils. Pretend each of these speakers are tweeters.
September 14, 201016 yr Ok I understand you can run series and parallel, but I thought that only applied to subs (where dual voice coils come into action)?Dont tweeters have only 1 negative and 1 positive?. So how can you pick whether to run in parallel or series?The only thing that comes to mind is this: AMP->Tweeter->Tweeter->Tweeter-Tweeter->TweeterA tweeter is connected to the other one, then the other, then the other until the final one reaches the amp. Is this right?You can series anything with voice coils. Pretend each of these speakers are tweeters.You forgot to replace the woofer pics with tweeter pics.
September 14, 201016 yr Are the new T series Fosgate amps 1ohm stable in stereo. My silver T300.2 was. That damn amp was a beast.
September 14, 201016 yr Author Ok I understand nowBut tahoe has 12 tweeters. 4 on each front door, 2 on each pillar and 2 more on the rear doors.With 6 tweeters, how would you get 4ohm load? Edited September 14, 201016 yr by slim142
September 14, 201016 yr Ok I understand nowBut tahoe has 12 tweeters. 4 on each front door, 2 on each pillar and 2 more on the rear doors.With 6 tweeters, how would you get 4ohm load?You wouldn't need a 4ohm load, he was just posting the picture for example purposes. Most 2-channel amps are stable to atleast 2ohm stable per channel, and some are 1ohm stable per channel (which I believe the RF Power amplifiers are 1ohm stable per channel). As long as the final impedance is a load the amplifier is stable at, that's all that matters.
September 14, 201016 yr Author You got a pointThanks for clarification.If I ever get 4 components for each door, ill come here and ask for the wiring setup lol
September 14, 201016 yr it depends the ohmage can be so low or pretty high but he most likely has it at 2 ohm but i can run 100 woofers to 1 amp and not have a problem as long as it is in the right impedance for the amp.I leaned a new word today, "Ohmage"
September 14, 201016 yr it depends the ohmage can be so low or pretty high but he most likely has it at 2 ohm but i can run 100 woofers to 1 amp and not have a problem as long as it is in the right impedance for the amp.I leaned a new word today, "Ohmage" lol I am the creator, seems pretty legit though........and has a good meaning
September 14, 201016 yr it depends the ohmage can be so low or pretty high but he most likely has it at 2 ohm but i can run 100 woofers to 1 amp and not have a problem as long as it is in the right impedance for the amp.I leaned a new word today, "Ohmage" lol I am the creator, seems pretty legit though........and has a good meaning Ohmage
September 15, 201016 yr You got a pointThanks for clarification.If I ever get 4 components for each door, ill come here and ask for the wiring setup lolYour hugging Steve Meade's nuts harder then a squirrel.
September 15, 201016 yr You got a pointThanks for clarification.If I ever get 4 components for each door, ill come here and ask for the wiring setup lolYour hugging Steve Meade's nuts harder then a squirrel.DDDDDDDDDDDDDDAAAAAAAAAAAMMMMMMMMMMMMMMMMMNNNNNNNNNNNNNNNNNNNNNNNNNNNNthat is some major nut hugging. Just like the squirrel from ice age.
September 15, 201016 yr You got a pointThanks for clarification.If I ever get 4 components for each door, ill come here and ask for the wiring setup lolor go here???? http://www.the12volt.com/caraudio/woofer_configurations.asp
September 15, 201016 yr it depends the ohmage can be so low or pretty high but he most likely has it at 2 ohm but i can run 100 woofers to 1 amp and not have a problem as long as it is in the right impedance for the amp.I leaned a new word today, "Ohmage" lol I am the creator, seems pretty legit though........and has a good meaning OhmageOh snap. Guess your not cool anymore cheese.
September 18, 201015 yr it depends the ohmage can be so low or pretty high but he most likely has it at 2 ohm but i can run 100 woofers to 1 amp and not have a problem as long as it is in the right impedance for the amp.I leaned a new word today, "Ohmage" lol I am the creator, seems pretty legit though........and has a good meaning OhmageDamn I guess I had a pretty good use for the word in the sentence.....LOL! Nice Find! Edited September 18, 201015 yr by cheese20323
