Posted September 18, 201016 yr Just got a Fluke 87 ture rms multimeter My linkI don't know if it is accurate or what but i read the owners manual and am mind boggled. how do I tell the voltage readout on this thing?It says ac voltage=2.5 but i know thats not right. any ideas??ThanksMatt Cusack
September 18, 201016 yr for starters what are you measuring? battery voltage? amp output? but i assume you are measuring the amp output b/c you are in the a/c setting and you are setting your gain...so with this first disconnect the sub then put the dmm into those terminals and play a 50-60hz tone and turn your h/u 75% of the way up and this is for the sub stage i am talking about
September 18, 201016 yr Author I'm trying to measure the voltage on my amp so i can adjust my stinger voltage meter
September 18, 201016 yr o in that case put the fluke on DC the --- not the ~ symbol and touch the positive and negative terminals on the amp, where you plug the wires into to give the amp power! remember the amp TAKES DC voltage and outputs A/C voltage
September 20, 201016 yr not a thread high jack... but...I want to setup my JL Audio amplifier so I can get the correct gain setting...What do I select on my DMM? Thanks
September 20, 201016 yr not a thread high jack... but...I want to setup my JL Audio amplifier so I can get the correct gain setting...What do I select on my DMM? Thanks2 Clicks to the right. 200 acvBlack cord in the com port, red cord in the left port. (10a)
September 20, 201016 yr not a thread high jack... but...I want to setup my JL Audio amplifier so I can get the correct gain setting...What do I select on my DMM? Thanks2 Clicks to the right. 200 acvBlack cord in the com port, red cord in the left port. (10a)Thanks... Jumping in the car now!
September 20, 201016 yr So I tried last night and again this morning .... Only thing that happened was this threw my amplifier into "low impedance" mode ... I didn't get any real readings at all...
September 20, 201016 yr So I tried last night and again this morning .... Only thing that happened was this threw my amplifier into "low impedance" mode ... I didn't get any real readings at all... The red cord actually goes into the right port. A is for Amps, V ohm etc is what you want for voltage.edit: Whoops, your left, not the pictures left lol. Disregard this if you put it in the right one. Edited September 20, 201016 yr by ulrisa
