Posted September 29, 201014 yr Okay so the other day i noticed my system was not playing the same. It seems to be playing at half of its potential! So i waited and didn't listen to it for one day.. didn't even drive the truck. I just now took it for a ride and its true... something is wrong! I pulled into an empty parking lot and played it at full tilt with the truck running in park, i was steady at 14v.. MY system is not suppose to be steady at 14v, i hit 151.8 dBs parked and the voltage dropped to low mid 12s and it was at the same volume as it was when i hit 151.8It seems like the subs are only getting a couple thousand watts of power.No i am not getting use to it.. I checked all 0gauge connections and grounds going into the amp and batts and around the whole truck.The inline fuses for the amps to batteries aren't blown, alt fuse isn't blown, no fuses are blown.I pushed down on both of the subs and the surround is still stiff and i did not hear ANYthing.. no coil rub.. weird sound.. nothing, just silence. The subs/coils don't and never did smell.Whats wrong here guys? I'm starting to freak out
September 29, 201014 yr Grab a DMM and test the coils on the subs.AirLFTN:lol crazy ass user names nowadays weres "not Steve Meade" Edited September 29, 201014 yr by cheese20323
September 29, 201014 yr stupid question but I'll ask anyways since this thread is just odd, your headunit settings haven't been changed since?
September 29, 201014 yr Author Just bring it down and I'll figure it outI cannot tonight, but tomorrow after work i can. Thanks mark!stupid question but I'll ask anyways since this thread is just odd, your headunit settings haven't been changed since?No settings have been changed.
September 30, 201014 yr Author So there was no real issue... we just turned the settings up (really odd.. idk why) and i'm not only just as loud.. i'm louder 152.6!
September 30, 201014 yr bass vibrations made the truck scared and it turned your gains down by itself. Duh.going for 153.X now?
September 30, 201014 yr That's odd, well if your gain was turned down from the bass then your ssf may of done the same...
September 30, 201014 yr Next time, you'll know what to do !I did not understand what happened, hope you did !!! When you talked about settings, was is only gain settings ? So, the gain turned down under too much bass pressure ! Damn !
October 1, 201014 yr Author Maybe the amps get rattled so hard the Gain get's turned down?Gain was at the same.bass vibrations made the truck scared and it turned your gains down by itself. Duh.going for 153.X now? FUCK YEAH! 154 son! hahahDamn nice Sir!Happy for you that it turned out to be nothing.Thanks man!That's odd, well if your gain was turned down from the bass then your ssf may of done the same...Bass did not turn my gain down.Next time, you'll know what to do !I did not understand what happened, hope you did !!! When you talked about settings, was is only gain settings ? So, the gain turned down under too much bass pressure ! Damn !I think....the suspension was stiff so with little gain it hit hard and tight and now the suspension is loose so it needed to be turned up? ..not realistic but only thing that comes to mind.
October 1, 201014 yr You ended up taking it to Air.LFTN......kinda weird but now thats it's all good there should not be problems.
October 1, 201014 yr Author You ended up taking it to Air.LFTN......kinda weird but now thats it's all good there should not be problems.Weird how?
October 1, 201014 yr Weird how it just lost output but you got it fixed and it ain't a problem anymore.
December 6, 201014 yr Author Weird how it just lost output but you got it fixed and it ain't a problem anymore.Late response i know, but Mark and I said the same.. i'm just glad it's fixed.
