Posted October 3, 201015 yr I have a 2009 Ford Escape with factory sirius installed. My question is i have my Alpine CDA-9887 from my 05 escape that i'm putting in and want to know if i need anything else to get sirius through my alpine besides the KCA-SC100Sirius Satellite Radio Plug and Play Interface.? Does the factory installed sirius unit plug into the kca-sc100? Do i have to buy anything else??
October 3, 201015 yr If the plug from the Sirius will plug into the KCA-SC100, you shouldn't need anything else. the HU is the controller.If you are unsure, then post a picture of your sirius plug, And I will post the plug ins on the SC100.
October 3, 201015 yr Author ok will do I'll try an pull the factory radio out today and see what plug it is Edited October 3, 201015 yr by jj1479
October 6, 201015 yr Author ok theirs the picture sorry it took so long pain in the butt to get the radio out
October 7, 201015 yr If I had to guess, the plug end you posted is only the antanna wire. As I have a Sirius tuner/receiver that the antanna plugs into.Close up of the plugs that go to the Sirius tuner.And then sirius signal travels into the SC100 with the pin plug.and this is the plug that gos into the SC100
October 8, 201015 yr Author Ya i didn't see any other plug besides the regular wiring harness but i didn't pull it the whole way out. I'll pull it out later and check again.Since my Sirius is installed from the factory do you think the plug is different?
October 8, 201015 yr Author well i think i need that sirius box like you have cause i think mine is built into my factory radio
