Posted October 6, 201015 yr Hey probally just spitting in the wind with this question but figured yall could have some idea or thought.Im picking up a 1992 volvo 240 wagon and im a big power hungry type person and need a nice beefy alt that can perform well and pump over 100amps of charging powerMy problem is YOU CANT FIND ANY alt's over 100AMPS of power that fit onto the mounting spot, any type of alt anybody knows of that would fit or someone that could custom make something to fit my application. Gave up on the sedan and just put a bosch 100amp in it, worked ok just enough amperage for my needs atm. Would really appreciate your input on this foreign car issue. Edited October 6, 201015 yr by Dictator1992
October 6, 201015 yr I would have to check my reference book for dimensions to make sure, but that shouldn't be a problem to handle.. Your only limitation is the 2V belt setup on bigger alternators, but you should be able to run 200 or so without any issues.. Rob
October 6, 201015 yr Author That would really be great if you could check that out for me rob. The first real answer ive heard
