Posted October 9, 201015 yr i was looking into getting a new system i looked at this amp an re audio vlx 3de and running two subs. i know it would split the wattage between the subs but how do i wire the subs to this one amp? any help i know its a stupid question but it still confuses me.
October 9, 201015 yr What would your final load be? 1 ohm?To get down to a final 1 ohm load you would have to buy either dual 1's or dual 4's
October 9, 201015 yr Author i guess what im needing to know is how u connect the wires from to the other sub to the amp.
October 9, 201015 yr Author one ohm i mean i understand the wiring part but i just dont understand what people use to connect the wiring going from one sub to the other sub then to the amp. do they splice them then solder them together or what? Edited October 9, 201015 yr by bjballar41
October 9, 201015 yr one ohm i mean i understand the wiring part but i just dont understand what people use to connect the wiring going from one sub to the other sub then to the amp. do they splice them then solder them together or what?just have your standard 12 gauge wire going from amp to the first sub and then just use 12 ga as a jumper to the other terminals
