Posted October 10, 201015 yr guys,im looking 2 bulid a new box for my ia li 12 inch,can sum1 give me d specs for 1?looking for it to hit the lows yet be very chest pounding!please give dimentions for box!thanks,its going in a 1996 nissan sentra,it will be getting 900 rms
October 10, 201015 yr Author I need dimensions and..... Never mind just dimensions.the box cant be wider dan 18 inches,it cant be more dan 15 inches high,dept cant be more dan 21 inches,im looing 2 go ported by d way
October 10, 201015 yr You Fail. Try again in a week or so. sorry lancelot i accidentally -1 you i meant to +1
October 10, 201015 yr I need dimensions and..... Never mind just dimensions.the box cant be wider dan 18 inches,it cant be more dan 15 inches high,dept cant be more dan 21 inches,im looing 2 go ported by d wayWhat is the inside dimensions of the your trunk?
October 10, 201015 yr You Fail. Try again in a week or so. sorry lancelot i accidentally -1 you i meant to +1+1 now but is at zero....
October 11, 201015 yr so no1 guna help me?16.5x13.5x18= 2.3 cu.ft before port; those are inside box numbers, Most 12's will work in that size box.
October 11, 201015 yr Author so no1 guna help me?16.5x13.5x18= 2.3 cu.ft before port; those are inside box numbers, Most 12's will work in that size box.what about the port,i need 40 inches of port tuned to 35
October 15, 201015 yr :puzzled: OMG ! why cant u type proper english so that ppl can understand wtf u are saying
October 18, 201015 yr Come on guys give him a break.....hes from Trinidad, which just happens to be a country that imports tons of IA gear now Hey man, the recommendation above of 2.3 cubes is great. Externally the box would be 18x15x19.5, and internally that would give you 16.5" x 13.5" x 18", with a port of 13.5" x 3" x 33.5" deep. That will get you roughly 35 hz tuning.Thanks!
October 19, 201015 yr 35HZ is a perfect tuning for the LI series! It will be nasty on the lows and will have that transient response your looking for!Good luck on the build!We will demand pics of the enclosure when building and vids when completed!
