Posted October 11, 201014 yr looking for best sq 8" woofer for mid-bass...either want 1 or two woofers...looking for any sugestions...no price range and i have up to 500 watts to work with
October 11, 201014 yr need more detail, no such thing as best anything without an applicationmidbass IS stereo btw
October 11, 201014 yr need more detail, no such thing as best anything without an applicationmidbass IS stereo btwx2 bro !!! sub transducers and mid drivers are 2 totally different animals ...
October 11, 201014 yr As for a sub the American Bass XD8 works good. Mid-bass..........I do not know.
October 11, 201014 yr What is the rest of your front stage?Mids and tweeters?How much power will you have available and what processing will you use for a 3 way active front?
October 11, 201014 yr Admin I think Brad mentioned something about the Bravox 8's being a decent candidate, but I have not had a chance to run the specs.
October 11, 201014 yr Author alright i will look into the bravox 8's and i have polk db 5.24 components and i have 500 watts rms available
October 11, 201014 yr You could add the SLS 8 on the list, based on the upper frequency limit. It could very well dig deeper than 100hz. Mounting depth available ? Door mounted (IB), or sealed ? MORE details.
October 11, 201014 yr Admin You could add the SLS 8 on the list, based on the upper frequency limit. It could very well dig deeper than 100hz. Mounting depth available ? Door mounted (IB), or sealed ? MORE details.Yes, the Peerless are very nice.
October 12, 201014 yr Author it will be in a sealed box....im taking out center console and building a custom enclosure
October 12, 201014 yr it will be in a sealed box....im taking out center console and building a custom enclosurenot what you would want to do for midbass my friend
October 12, 201014 yr Author what should i do then.....it will be going in a 1998 pontiac bonneville se
October 12, 201014 yr You will want two midbass speakers on opposite sides of the vehicle. Ideally located as wide as possible, and ideally they would be equal distances from your head. Placing them in the middle of the car would be a mistake.
October 13, 201014 yr Where you'd want to put them would depend on where you have your polk speakers and what your level of fabrication is. My first effort would be to put them in the kicks, but if you have the mid and tweeter there then the door.. or vice versa.. more info needed to get you a complete answer
October 13, 201014 yr You really think you need 8s ? 6.5s not strong enough ?? whats the rest of your system consist of ??
