Posted October 12, 201016 yr A lead came off my BTL as I explained here.Wondering if this lead is the proper size/wattage...or possibly what you would recommend.Love my sub...thanks for the help!~Abstract~
October 13, 201016 yr I wouldn't use that..If you want to replace the tinsels a tinsel and dustcap kit is 15 bucks..you cannot just solder a piece on the end of that, you have to pull the old tinsels through the cone and solder a knot under the dustcap, glue it back down and bring the new tinsels back through the cone..
October 14, 201016 yr Author I wouldn't use that..If you want to replace the tinsels a tinsel and dustcap kit is 15 bucks..you cannot just solder a piece on the end of that, you have to pull the old tinsels through the cone and solder a knot under the dustcap, glue it back down and bring the new tinsels back through the cone..How much would you (Fi) charge for a foot of BTL tinsel?Thanks.
