Posted October 15, 201014 yr FS 27hzQms 4.71Qes .407Qts .375Vas 75.69 liters 2.67 ft^3sd 466 cm^2 72.2 in^2xmax 24.86 mm .979 invd 2316.6 cm^3 141.37 in^3ref spl 87 dbxmech 31.61 mm 1.244incoil od 79.83mmcoil surface area 7959mm^2re 3.87 ohmsle 1.331 mhbl 15.06mms 138.83 gramscms .250 mm/nDrver weight 37 poundsdriver cutout 11 inchesmotor force 58.65 Bl^2/reacceleration 108.5 bl/mmspeak gap flux 6012 gausseffective ebp 66bl limit @ 93% 86% 79%excursion mm @ above bl 17.84 21.42 23.36Once these figures are verified by my independant lab preorders on the 12 and 15 will begin. Possibly in one week.
October 15, 201014 yr Author The goal was to come up with the best possible sounding sub under $300. While using the least amount of power as possible. You will see this for sale in stores between $260-$280. And although the thermal rating is high it only needs about 250 watts to reach its average xmax and 300 to 400 watts to reach its peak xmax of 24mm. The main advantage besides the fact the sub sounds amazing, is the consumer can possibly spend half as much money on their power supply when compared to anything else on the market that has comparable output levels as the Genesis.oh....just in case i didn't mention it, the Genesis is an xbl^2 sub. Edited October 15, 201014 yr by Audibel Customs add info
October 16, 201014 yr So what is the competitive advantage of this driver over, say, an Exodus Shiva-X2?Shorting rings in the motor? If so, what kind and where?
October 16, 201014 yr Author The exodus appears to look the same, is about $42 cheaper but looks like it is on sale for the fall, and has 1.14 more excursionhowever its EBP is 47.33 which means it is geared more towards sealed, the Genesis' EBP is 66 which makes it more ported friendlyThe Genesis has a 18mm aluminium shortening ring between the washersThe Genesis has a stronger 6 spoke basket, but I doubt the 12 spoke on the exodus has any problems, I specifically did not want that basket b/c other companies have had problems with them in the past.The genesis has a stronger motor with a qes .407 versus a qes of .45 of the ExodusThe genesis has a lighter moving mass of 138 grams versus 206 grams of the ExodusWhich makes the genesis a more efficient subwooferThe Exodus has a Pmax of 1000w the Genesis a Pmax of 2964w, almost 3 times the thermal rating. They don't list a rms rating but given it has a heavier moving mass and weaker motor and tighter suspension I would assume it would need more rms power to achieve xmax. Edited October 16, 201014 yr by Audibel Customs add info
October 20, 201014 yr Author The prototype went out Tuesday to Redrock acoustics, they should recieve it by Friday. we should have some info by the beginning of next week.
October 20, 201014 yr Author The specs should be what's listing in my section. I recieved full Klippel analysis from Dan when I recieved the sample from him. But I want to be 100 percent sure before I start the presale. The 12 will start at $195 which includes shipping, plus discounts for multiple driver purchases. The 15 will be about $20 more.
November 19, 201014 yr Author We are looking at a few modifications but will have something to show in a few weeks.
November 28, 201014 yr Any pics at all? Sound like a solid driver, at a nice price!Never mind, i found the topic that holds the proto pics.
