i still say 4 e-8's sealed. should be hella accurate w/ great output also.
  • Replies 57
  • Views 6.2k
seat lift kit would definitely be a great idea. where did you buy that steve?
I couldnt kind one so i made one.
do you think some re 8's could work? i see they're only 5 1/2" mounting depth. maybe i could build a box using 1/2 mdf on the bottom or something and make the box 6" tall in the front? hopefully that wouldn't hit the bottom of the seat.
also i saw that RE makes a shallow mount 10 and 12. SL series i think. any thoughts on that sub?
thanks alot for the help steve
The picture at the top of the page with the two sundown amps is 4 re8 sealed firing down on 1500w without a seat lift. the bottom of the seat is soft and will move a little.
awesome. do you think that would be a good way to go? 4 re8's sealed firing up?
No. firing down. i busted my first two sa8s firing them up
Knows what he says about these type of trucks....I heard the Sl's from RE are kinda cheap just stick 4 RE 8's
yeah sounds like the plan at the moment. hey steve, how much space do you thing i should leave for the subs to move? definitely don't want them slapping the floor lol
about an inch...
