Posted October 20, 201014 yr I have a Jeep Cherokee that the A/C compressor has locked up on. So I have decided to put an alternator in its place. What do you have that will put out around 15v's and close to 275 amps? Also do you have the adapter to the alternator in that spot?
October 21, 201014 yr I have a Jeep Cherokee that the A/C compressor has locked up on. So I have decided to put an alternator in its place. What do you have that will put out around 15v's and close to 275 amps? Also do you have the adapter to the alternator in that spot?We've done a couple of brackets for the AC compressor spot on the Jeeps, so that's really no big deal now.. Our 270XP with the 15v regulator is exactly what your looking for spec wise, and hands down it's the best alternator you can get.. You can run one in the stock position as well if you want, we have those available now.. Rob
October 25, 201014 yr Normally with the bypass and harness they are $689, but right now I can do it for $599.. Let me know, Rob
