Posted October 18, 200519 yr Powerbass xs15dv2 4.834gross volume 3.997net volume 63.375 sq inches of port (3h x 21.125w) 22.854 port lenght tuned to 38hz powered by orion 1200d @ 1ohm Are my calculations correct? If so do you think that is enough port area? 4.834gross 4.459net 42.245 sq inches of port (2h x 21.125w) 15.344 porth lenght tuned to 35hz Which one would you chose?
October 18, 200519 yr Author What if I did the 1st enclosure with same net volume and same port and just bolted on a sheet of mdf .75 same lenght and width for daily? 3.997net 47.531 sq inches of port (2.25h x 21.125) 22.854 tuned to 33.4hz
October 18, 200519 yr Admin you can try it, but I think the XS is a pretty versital sub, so I think it will do well in either box, just the tuning is up to your preference
