Posted October 20, 200520 yr I just scored one of these on ebay for $70 shipped. It was a store display model. Did i get a decent deal? Also if anybody has any info or box specs they can give me i'd appreciate it.
October 20, 200520 yr Admin good sub Power Handling (Rms / Peak):400 / 800 wattsFrequency: 36Hz - 750HzNominal Impedance: 4 ohm + 4 ohmSensitivity (1W / 1M): 87.4 dBFs: 36Hz / Vas (Liters): 32.1Qts: .52Non-Pressed Kevlar Composite Spruce Pulp Paper ConeOne Piece Chrome Plated Custom CNC Machined Bumped Backplate and Extended Pole PieceBlack Anodized High Temperature 4-Layer Aluminum Dual Voice CoilsHigh Excursion Oversized Black Conex Linear Spider with Woven High Current Tinsel LeadsCompetition Die-Cast Aluminum Basket with Voice Coil Perimeter AeroventsHigh Profile UV Treated Rubber Surroundhope that helps
October 20, 200520 yr Author Thanks D, it looks like it may work in the same box Kent built for my Eclipse but i need to know the cutout diameter. Anybody?
