Posted October 28, 201015 yr i have a 2004 Chevy Blazer 2 door. my Bosch battery did fine when i was funning a little 300 watt system not long ago but i recently upgraded and am pulling over 1200 watts rms between my mono block and 4 channel.i want to run one single battery right now but will eventually run a second or more in the trunk area. What would you suggest for me? i'm looking at the d3400.. its a tight squeeze but i can make it work. is this a good idea?
October 28, 201015 yr Yeah that will work fine for you. If you are using side terminals, then you will need the Ibar Kit 551 also.
October 29, 201015 yr Author awesome. thanks a lot. i just wanted to make sure i wasn't going to be spending money and finding out i'd messed up. i won't be upgrading anything else until next summer. battery and alternator are it for now
