Posted November 8, 201015 yr Hey all.Im going to be getting a Blazer or something similar here in a few months.I was wondering if a 21" Incriminator Audio Warden would be better than 2 FI BTL 18" subs in the Blazer.I would power the sub or subs with a AQ2200.I will eventually get a bigger amp or a second AQ2200 but for the time being ill be using just the one AQ2200.I know this is probaly a real n00b question but I would like to know which would be the best before i go out and spend all the money.Thanks.Oh yeah I forgot to mention that I would mainly listen to music and show off but I would like to get into some competions if I couldHawkEye Edited November 8, 201015 yr by HawkEye
November 8, 201015 yr Yes it is a noob question! What series of BTL are you looking at comparing to the Warden?
November 8, 201015 yr 2 18s would have a lot more cone area, and overall power handling. Also have you actually measured to make sure you wont be building a wall to fit those 2 18s? It'll be high enough to make the windows pretty hard to see out of from my blazer experience.
November 10, 201015 yr I have two SSD18's and in comparing them to the Warden 21", they hit way harder and sounds so much cleaner with less power compression. I hate to see single subs, they always looks lonely to me. That's why I would go with dual 18's. Or dual 21" or 22" drivers once they come out. Just remember that two vs. one means twice as much port, power and airspace. If you can afford that, then definitely go dual drivers.
