the XTv3 is by far our best selling amp in our line up despite being the mid price level. we do cadence and phoenix gold as well.
all our dealers are pretty happy with the v3s. and the most common install is having an 800.4v3 powering speakers upfront and rear bridged 4ohms to either an SRX or SEX series subwoofer. with this set up you can expect to be quite loud and clear without too much drain on the electricals.
amp does not heat up much also because of the class D design. only issue i have on this amp that it sounds better with the gains turned up between the 10-12 o'clock position.
good luck on your quest...
for now I am not needing one. I am going to run a JL 500/1 cause I got it cheap. I also got some eclipse amps new in box for ridiculous cheap so I dont need anything right now. I will keep these in mind
