Posted November 17, 201014 yr My sub is dual .7 ohm and I'm planning to do 1.4 ohms, what will be the best amplifier for it stable at 1 ohms or 2 ohms?TIA
November 17, 201014 yr So your driver is Dual 1ohm. You can wire it to 0.5ohm (not recommended) or 2ohms. Wiring DiagramYou can always get an amp stable to 1ohm for future use. Say in the future you get another dual 1ohm driver, then you can run the amp down to 1ohm.
November 17, 201014 yr Author So your driver is Dual 1ohm. You can wire it to 0.5ohm (not recommended) or 2ohms. Wiring DiagramYou can always get an amp stable to 1ohm for future use. Thank you for the inputs, I thought it will be better to use 1 ohm even my configuration is 2 ohms.
November 17, 201014 yr Just to clarify, you are reading the Direct Current Resistance(DCR) of your coils, they are in fact D1 coils.
November 17, 201014 yr Author Just to clarify, you are reading the Direct Current Resistance(DCR) of your coils, they are in fact D1 coils.Ok, thank you for pointing it out.
November 17, 201014 yr You can always get a regulated amplifier that will do the same power at either load.
November 21, 201014 yr Author You can always get a regulated amplifier that will do the same power at either load.can you mention couple of brand that can do that feature?
