Posted November 20, 201015 yr Which is better to get: dual 1 or dual 2 Fi SSD12 subs? I'm thinking of getting two subs and going with a sundown SAX 1200 amp. Does it matter? Pros and cons of each?
November 20, 201015 yr If wiring them to an SAX-1200D at 1 ohm you need D1 coilsThey are different for wiring flexibility.
November 20, 201015 yr The SAX-1200D is optimized for 1 ohm loads, nothing lower. I would recommend the dual 1 ohm if your going for a pair of subwoofers or dual 2 for a single subwoofer.
November 20, 201015 yr Like Duran said, it's for different wiring options. No pros and cons. the12volt Use that link. It will show you how to wire the different subs. Like they were saying wire the subs to 1 ohm on the amp, dual 1's for 2 subs dual 2 for only one sub.
