Posted November 22, 201015 yr Hey Andrew,your 1st box is holding up great... Just not hitting the lows as hard as I wanted, mainly due to me keeping the box pretty small for a 15... I wanna go BIG this time, with as much volume and port area as possible ! Could you quote me on a new box?- Max dimensions are 34"Width x 18"Height x 20" Depth- I want to get 4 cubes if possible with 16-18 sq.in. of port area, 30hz - Sub/port back, no carpet, double baffle, regular port.Sub Info:Sub OD: 15.625”Cut ID: 14.125”Mounting depth: 8.500”Displacement: 0.19cuftTake your time, and thanks in advance! Edited November 22, 201015 yr by bimmerboy
November 22, 201015 yr Author a little less than 3cubes since the box design was orig. for a SSD but then a changed my mind and got the Q which has more sub displacement....
November 23, 201015 yr Ahhh that's right! I forgot why it was low for a Q. I will get a design going and get a price for you. Andrew
November 27, 201015 yr Ok, I was able to fit 3.75 cubes with 57.75 sq inches of port. I used your max dimensions of:18 tall20 deep34 wideI am indenting the sides 3/8th of an inch, if you would like no indent I can try and get closer to 4 cubes. This enclosure will cost: $148.75 plus shipping. This price includes the 15% off. Andrew
November 27, 201015 yr you should be hella happy with a larger, lower tuned box.i went from 3 cubes at 33hz to 4 cubes at 31hz, and boy does it make a difference!
November 29, 201015 yr Author Ok, I was able to fit 3.75 cubes with 57.75 sq inches of port. I used your max dimensions of:18 tall20 deep34 wideI am indenting the sides 3/8th of an inch, if you would like no indent I can try and get closer to 4 cubes. This enclosure will cost: $148.75 plus shipping. This price includes the 15% off. AndrewOK I need to sell my old box before I get the new one... Will keep you informed. Thanks for the info.
