Posted November 22, 201015 yr Alright mono block it is! I dont know what was happening before but everything is fixed now.I think a 3500D should be enough (for now) to power BLs sufficiently. Edited November 22, 201015 yr by Hell-Razor
November 22, 201015 yr There are FEW amps that do 1000rms per channel on a 4 channel.Why do you need that? A mono block work better for subwoofers.
November 22, 201015 yr Author He's looking at 1000w MAX amps what are you powering up we need more info. I updated just as you posted
November 22, 201015 yr There are FEW amps that do 1000rms per channel on a 4 channel.Why do you need that? A mono block work better for subwoofers.Indeed. With the multiple wiring options of the dual voice coil woofers, one or two mono block amplifiers would be much more efficient and probably cheaper.
November 22, 201015 yr Monoblock amp is the way to go. Plus you don't need separate channels for the sub stage.
November 22, 201015 yr Author Something happened before and I couldn't post, all fixed now. After reading the quick responses I will keep my 3500D for power! I will start up what I have in my head in my build log to try and keep things organized.
November 23, 201015 yr Something happened before and I couldn't post, all fixed now. After reading the quick responses I will keep my 3500D for power! I will start up what I have in my head in my build log to try and keep things organized.Not to mention, less wiring to send out of the amp for sure.
