Posted November 30, 201015 yr Hello,I am building a box for a friend and I had my MDF all ready to cut, measured out panels and everything and he calls and tells me that he want an aeroported box. I have searched and read different things in this section and after figuring out slot is actually a lot more different than aero ported, I just don't get it.So, I have come for some box designing help.Dimensions:Depth: 16Height: 16Width: 40It is for an Fi X 12.Was hoping for 2.0ft^3 at 32hzI really just need to know how many flared aeroports I would need with no port noise. Diameter and Length of the aeroport would be nice.Thanks in advanced,Jay
November 30, 201015 yr Go with 1 4" Aero and with length go here ... http://www.psp-inc.com/tools.html Could go with 1 3" as well. Vent mach will be low enough to not be audible. http://www.linearteam.dk/default.aspx?pageid=ventcalculator
November 30, 201015 yr Author Thanks guys. PSP calc said 2 cubic feet. 32 hz. Port diameter: 4. 1 port.Length or flared port would need to be 14.066 inches.Forgot one thing. I am going to buy this 4" flare and 18" tube and cut it to 15". How much discplacement would this take up in a box. Edited November 30, 201015 yr by Hzd Skizzy
November 30, 201015 yr Thanks guys. PSP calc said 2 cubic feet. 32 hz. Port diameter: 4. 1 port.Length or flared port would need to be 14.066 inches.Forgot one thing. I am going to buy this 4" flare and 18" tube and cut it to 15". How much discplacement would this take up in a box.You do math? lol I'm just kidding:area of a circle = r^2 x pi2^2 x pi = 12.56637in squared12.56637 x 15=188.495559in cubedGonna be more than that because 4in is the internal diameter, correct? and the flare itself will take up some room too. Estimate.
December 1, 201015 yr Author Thanks guys. PSP calc said 2 cubic feet. 32 hz. Port diameter: 4. 1 port.Length or flared port would need to be 14.066 inches.Forgot one thing. I am going to buy this 4" flare and 18" tube and cut it to 15". How much discplacement would this take up in a box.You do math? lol I'm just kidding:area of a circle = r^2 x pi2^2 x pi = 12.56637in squared12.56637 x 15=188.495559in cubedGonna be more than that because 4in is the internal diameter, correct? and the flare itself will take up some room too. Estimate.Heres what I came up with after some more doing and research.The whole aeroport will take up .10 cuft. 3.14x2x2x15/1728=.10xxxxxSo the box's internal volume after wood displacement but before port and sub is 2.24-.10 for sub (fi x 12)-.10 for port=2.04 cuft after all displacements tuned at 32hz.The psp calc for a 2cuft box @ 32hz with a 4" port it would need to be like 14.879 so rounded up to 15''.I think I've done this right.
December 2, 201015 yr Thanks guys. PSP calc said 2 cubic feet. 32 hz. Port diameter: 4. 1 port.Length or flared port would need to be 14.066 inches.Forgot one thing. I am going to buy this 4" flare and 18" tube and cut it to 15". How much discplacement would this take up in a box.You do math? lol I'm just kidding:area of a circle = r^2 x pi2^2 x pi = 12.56637in squared12.56637 x 15=188.495559in cubedGonna be more than that because 4in is the internal diameter, correct? and the flare itself will take up some room too. Estimate.Heres what I came up with after some more doing and research.The whole aeroport will take up .10 cuft. 3.14x2x2x15/1728=.10xxxxxSo the box's internal volume after wood displacement but before port and sub is 2.24-.10 for sub (fi x 12)-.10 for port=2.04 cuft after all displacements tuned at 32hz.The psp calc for a 2cuft box @ 32hz with a 4" port it would need to be like 14.879 so rounded up to 15''.I think I've done this right.Looking good. Now just slap it together and bump!
