Posted December 6, 201015 yr i know i might sound like a true newbie but when ordering a 12" icon, whats the difference between the dual 4 ohm coils and single 4 ohm coils options? which one do yall recommend? any input would be appreciated
December 6, 201015 yr it's going to depend on what you're going to want to run your amp at, resistance wise. with dual 4 ohm you can wire in parallel for a final load of 2 ohms, or in series for a final load of 8 ohms. With a single 4 ohm you are stuck at 4 ohms.
December 7, 201015 yr Admin The Icon has dual 2 ohm and dual 1 ohm coil options. The Dcon has the dual 4 ohm and single 4 ohm coil, is that the driver you were thinking of?
