Posted December 9, 201014 yr I just purchased one of the FiDay x series 300 watts rms subs and i was wondering if i could safely run 500 watts rms to the sub without blowing it. I have not had any experience with Fi subs so i dont know how durable the x will be.
December 9, 201014 yr I just purchased one of the FiDay x series 300 watts rms subs and i was wondering if i could safely run 500 watts rms to the sub without blowing it. I have not had any experience with Fi subs so i dont know how durable the x will be.as long as your gain is set accordingly I dont see why not. Its mostly the person behind the knobs why you see the woofers go poof
December 9, 201014 yr It is a 2.5" coil, it can only handle so much power. How much power your woofers handle is application dependent.
December 9, 201014 yr I just purchased one of the FiDay x series 300 watts rms subs and i was wondering if i could safely run 500 watts rms to the sub without blowing it. I have not had any experience with Fi subs so i dont know how durable the x will be.as long as your gain is set accordingly I dont see why not. Its mostly the person behind the knobs why you see the woofers go poofx2Not trying to be rude but all of these 'can i run xxxrms on my sub?' questions are kind of ridiculous. Try it for yourself, safely and non-stupidly. Slowly turn up the gain. Any signs of stress or clipping clearly means it's too much. Just don't be an idiot and be careful and you should be able to run more than rated.
December 9, 201014 yr It is a 2.5" coil, it can only handle so much power. How much power your woofers handle is application dependent.The FiDay Xs are only a 2" coil.500 is almost double what is recommended. I don't see any reason to, unless you're planning to cook the sub. Seems like you should have bought 2 for that power range.
December 10, 201014 yr 300w to 500w isn't so audible so just don't bother. Go ahead and use the amp, but set it so your drivers aren't stressed.
December 11, 201014 yr I'm running 300 to my 12" X. It is perfect. Does what it needs to do... sounds good.
