Nice install, and impressive scores for a single twelve. I'll definitely be picking up an N2 for my ride.
Thanks it is a 15 but its not quite 150 from the trunk... I am happy with 147, when I upgrade to around 4k watts maybe I can close in on 150, tho I think I am limited to around 148.5 no matter what I try.
You should definitely get an N2 (or a couple) for your car; join the exclusive Neo Fi Club :)
i like 1 ton woofers.. means they are good... lolz
Very impressive build LOG BRO! I really enjoyed your craftmanship! :fing34:
  • 1 month later...
179437_584195979586_17506340_33198629_1227936_n.jpg167241_584196014516_17506340_33198632_7050119_n.jpg166457_584196099346_17506340_33198636_5992789_n.jpg164340_584349686556_17506340_33199902_1727655_n.jpg164840_584349826276_17506340_33199909_1743246_n.jpg163893_584349936056_17506340_33199914_4008931_n.jpg167333_584349985956_17506340_33199917_5013468_n.jpg165695_584350065796_17506340_33199922_933486_n.jpg165146_584350115696_17506340_33199926_2554391_n.jpg
Finally retired the reliable Exide Orbital I've had under the hood, put an XS Power D1200 under the hood, still got the HC800s in the trunk. My voltage stays above 13.8 no matter how hard I bump it. Got a few shots of the akward battery compartment, and the big glob of petroleum jelly I put on the terminals.
Made a new wire cover for the left portion of the amp rack, finishing up work on the false floor and then its on to the door panels once it gets warmer out :)
I installed a Stinger voltmeter next to the inverter too... almost forgot. Makes reading the voltage a lot easier on the fly, matches my red/blue light scheme too.
Edited by SubSam
Night time shot of the new Fi wire cover
Nice. Great work for a driveway build. Mad props on craftmanship bruh!
