Posted December 27, 201015 yr I'm going to build a box for a buddy of mine that has a 1988 Camaro Iroc-Z.It's not going to be in the wheel weld as of other boxes.But right behind the rear seats.In this picture where the amp is located, there will be an enclosure for them, and it won't cover up the whole trunk area.I am going to use dual 4" Areo ports, and I was wondering how long will they have to be to have a tuning of 32-32hz.I'm thinking 1.6-8 cubes in total for both subs, and the amp I am using is a Polk Audio 4channel 800 watt amp that will be bridged to run at 4 ohms.The aim is mostly for SPL since there is no true SQ.But he would like to be able to listen to a variety of music, such as: rock, rap, alternative, just about any random think you can think of. not really..His system as of right now is running an Alpine CDA-9884 running Infinity 4x6 fronts, and pioneer 6x9, and will be removing the extra set of 6x9 running off the amp.Just a little help, if you can.Thanks SSA!
December 28, 201015 yr Author I was thinking L port, but he wants areo's.If anything, I can do more then 2 ports, thanks I haven't calculated the space yet because his car is in the shop since he spun all of his bearings.. lol waiting for a new motor
January 14, 201115 yr I'm going to build a box for a buddy of mine that has a 1988 Camaro Iroc-Z.It's not going to be in the wheel weld as of other boxes.But right behind the rear seats.In this picture where the amp is located, there will be an enclosure for them, and it won't cover up the whole trunk area.I am going to use dual 4" Areo ports, and I was wondering how long will they have to be to have a tuning of 32-32hz.I'm thinking 1.6-8 cubes in total for both subs, and the amp I am using is a Polk Audio 4channel 800 watt amp that will be bridged to run at 4 ohms.The aim is mostly for SPL since there is no true SQ.But he would like to be able to listen to a variety of music, such as: rock, rap, alternative, just about any random think you can think of. not really..His system as of right now is running an Alpine CDA-9884 running Infinity 4x6 fronts, and pioneer 6x9, and will be removing the extra set of 6x9 running off the amp.Just a little help, if you can.Thanks SSA! Both ports will need to be 31" long for 1.6 cu. ft, that doesn't include displacement of the port. However, that's on the big side for that sub so I definitely wouldn't want more power than what's there, maybe even a little smaller box.
