Posted January 5, 201114 yr when u enter the box design posted on the forums for the ssd into the re box calculator i get a tune of 30 hz ??? is this right cuz i need to change the dimensions a bit for it to work for me i making a rear center console for a 10 ssd. and also i can only seem to get 17" of port area not the 27 i assume i need will this be a problum ??? and also i will not have a L port just a straight slot. any suggestions or help would be appreciated thx Edited January 5, 201114 yr by lea
January 5, 201114 yr 17" of port area total? or per cubic foot?The only reason some boxes have "L" ports is because they are longer than others. they have to put the port somewhere, so they go with the walls of the box. there is no difference than a straight port like you're thinking of.And when you're changing lengths on a box, you cant just take an inch from the height an put it in the length. it adds and subtracts different amounts of area. think about it, that's why your tune can be off of what they have.
